GPWER
- Mar 21, 2020
- Recall USA
- 2019 2DR JL RUBICON
I have seen and read many posts on this issue leaving out critical info. First of all I never lost axle locker function just reminded often by annoying alarm. My dealer experience to correct it was less then satisfying that's being polite. Jeep and dealers clearly don't stand by their product my opinion. They had my jeep 5 days with no end in sight. I took it out of there when it couldnt be fixed in that time or they chose not to work on it. I see many questions regarding the loose wire and location I found my bad pin connection at DTCM located behind the passenger rear panel this is the interior panel, there are many videos on removal on YouTube. After removing panel if you look again passenger side below and behind the rear seat belt tension-er there are three nuts holding a steel frame with a box with 3 multi connectors going to it, it is in one of those connectors that was my issue. If you aren't sure which wires to look for check out the wiring diagram below or the forum look under axle lockers look in and verify the pin is straight and level my pin was down not very noticeable. whether you have a light on or not I recommend strongly you strip back the electrical tape due to the stress of the harness and forced turns going to the DTCM is the culprit for the misalignment of the pins. I hope this helps.
https://www.jlwranglerforums.com/JL-Wiring-Diagrams/AXLE-LOCKER-SYSTEM.pdf
https://www.jlwranglerforums.com/JL-Wiring-Diagrams/CAN-C-BUS-LAYOUT.pdf
