WOLFBOX G900 PRO DASH/REAR CAM
Sonny
Los Angeles
2019 Jeep JLUR
I recently installed the Wolfbox G900 PRO dash/rear cam on my 2019 JLUR. I have to say it's really worth it. The video quality is top notch. I love the functionality of the whole unit. I love the fact that the front and rear camera records video at the same time no matter what's on the the screen (front, split or rear). Took me about 3 hrs to install.
The basic kit comes with the G900 PRO plus 4 fuse Hardwire kit. Wolfbox also has other accessories like OEM bracket for mirror dash camera if you want to remove your stock rear view mirror and replace it with the Wolfbox mirro/dash cam. They also have longer rear camera wire/cord if you are installing it on longer wheelbase vehicles like pick up trucks.
Installation can be done with the cigarette lighter power cord or with hardwire kit. I opted for the hardwire kit to reduce the clutter on my dash. Before the installation, I tested the unit by using the cigarette lighter power cord. I connected the power cord and rear cam cord to the mirror and put the ignition to on without running the engine and the unit started right up. The front, rear and split screen worked without any issues. Please see attached link of the installation video:
I started the installation by wiring the hardwire kit. The distributor box is located underneath the hood, passenger side. It's a black box that contains all kinds of fuses and relays.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2299
I couldn't find the ACC fuse so I decided to use the cigarette lighter fuse #F52 which only supplies power when the engine is running or if the push button ignition is at "on" position. It's a yellow 20amp micro fuse.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2295
I used the micro fuse tap/adapter that came with the hardwire kit. There are 2 slots for fuse, one for the dash cam and the other for the cigarette lighter.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2296
I connected the red wire of the hardwire kit to the micro fuse adapter, the yellow wire to the positive terminal of the battery and black wire to the existing ground bolt which located right next to the battery.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2297
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2298
I had to remove the driver side cowl cover so I could run the power cord behind the cover and under the rubber trim inside the passenger door, just right bellow the windshield.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2301
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2302
Then using the supplied tool, I removed the dash trim panel below the grab handle so and secured the power cord.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2303
Then using 10mm socket, I removed the grab handle bolts, only held by 2 bolts, top and bottom. You have to pry the covers to access the bolts. After removing the 2 bolts, gently pull the grab handle.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2304
Remove the passenger visor by using T25 torx bit then gently pull down the upper trim then guide the power, GPS and rear camera wires under the grab handle and upper trim leaving the end about 4-5 inches exposed right above the stock rear view mirror. Then tuck the rear camera wire under the front and back floor trim.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2306
Then remove the passenger taillight using T40 torx bit and disconnect it from the harness. Remove the jack compartment cover then the passenger side cargo hook panel using T40 torx bit (3 bolts).
Using T25 torx bit, remove the ONLY bolt right above the sub-woofer panel. Pry off the seat belt guide cover. Then gently pull the subwoofer panel away from the body. Then ran the camera wife behind.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2420
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2309
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2308
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2310
Right underneath the subwoofer panel, at the rear end, the are 2 small holes covered with transparent tape. Feed the end of the red wire (reverse/back up light wire) of the camera wire thru one of the small holes then connect it to the WHITE-PURPLE wire of the taillight harness using your preferred tapping connectors. I bought mine from Amazon.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2311
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2421
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2312
Then using remove the 3 bolts holding the tailgate panel. Feed the end of the camera wire through the vent panel and connect it to the rear camera. I secured the camera on top of my stop light using the 3M 2 sided tape that came with the kit.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2417
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2418
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2419
Using the short elastic fasteners (2 pcs), I attached the Wolfbox G900 PRO to the stock rear view mirror and connected the power, GPS and rear camera wires to the unit. Installation is complete.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2424
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2422
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM IMG_2423
Hope this helps. Please let me know if you have any questions.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
Sonny, thanks for the detail! Are you confident in the 3M tape holding the camera indefinitely? Or is there a more robust way to attach the rear camera?
Trail__Raiders
Sonny
Los Angeles
2019 Jeep JLUR
You’re welcome. I’ve used 3M double sided tapes for several applications on my jeep and they hold pretty good. For peace of mind, I used an electrical tape to secure the connections so I won’t lose the rear camera if in case the 3M fails😊🤟
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
That's the wide version, right? Did you lose the ability to use your sun visors?
Also, couldn't you have wired it into the back of the cig lighter? There's an adapter for that.
Trail__Raiders
Sonny
Los Angeles
2019 Jeep JLUR
I believe it’s the wide version. You will have to detach the visor from its holder clip and pull it out a little bit so you can lower/use it. No biggie.
I wasn’t aware of the adapter for the back of the cigarette lighter. But even if I was aware of it, I would still go for the hardwire kit to avoid exposed cord/wires on my dash😁
Ratbert
PNW
Software Engineer
It connects to the back side of the cig lighter. No wires on your dash.
rcoe
Rich
Michigan
2022 Gladiator Rubicon
I also have the 900pro and really like it. I also have mine hardwired and the rear camera mounted on the rear tire carrier.
Really a great solution when you have a large tire blocking most of your rear view. Yes it does cause issues with the drivers visor, but I have my windshield tinted so this really is not a huge deal.
Solid unit for the price.
Trail__Raiders
Sonny
Los Angeles
2019 Jeep JLUR
Glad you like your Wolfbox. Going to Sand Hollow next month. Excited to record some videos with the Wolfbox😁
DWS44
Rock Hill, SC (Charlotte, NC Area)
Toy Box: 2022 JLUR 392 + '17 C7 GS & '21 C8 Vettes
CAD/IT Manager (Civil/Airport Design)
I also recently purchased a Wolfbox and hardwire kit and planning to tackle the install in the next day or two. First dashcam install for me. For all those who have installed one using the hardwire kit, what recommendations would anyone have for which fuse to tap for constant power, rather than just when ignition is on?
Trail__Raiders
Sonny
Los Angeles
2019 Jeep JLUR
If you want constant power, then just use the yellow wire for the positive terminal and black for ground. Then just put electric tape on the red wire.
ducttape
Alan
Washington
2022 JLUR 4xE
Sr. Configuration Engineer
With the camera mounted outside do you run into issues with road grime or water obscuring the lens, especially in slushy/wintery conditions?
Trail__Raiders
Sonny
Los Angeles
2019 Jeep JLUR
I’ve only driven my jeep around town since the installation. We’ll see when I go to Big Bear Lake next month.
Sardaukar
Wisconsin
2023 JLUR 6MT, 2023 JT Sport S
Software
Commenting to save for later. I just added this as a dash mount and I just got the rear camera hooked up yesterday, but I'm still using the cigarette lighter for now. I plan to hard-wire in the near future, hopefully when it warms up again.
With the dash mount, I can still use the original mirror to see the kids in the backseat and will still have something if the rear camera stops working or gets covered in road grime/snow. Photo from initial testing before adding GPS and rear camera.
Jeep Wrangler JL WOLFBOX G900 PRO DASH/REAR CAM Wolfbox2
