Wire/Plug relocation
BranglerJL
Atlanta
2018 Wrangler JL Unlimited 2023 Lexus IS500
Anybody know what this circled wire is and if it’s able to be relocated? It’s towards the front of the rear passenger wheel well under the liner.
Jeep Wrangler JL Wire/Plug relocation IMG_6303
BranglerJL
BranglerJL
Atlanta
Still haven’t been able to find this info :(
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
Why do you need to relocate it? It's generally covered by the fender liners.
LanceMagnum
New England
2020 JLUR
That *might* be a bunch of canbus lines - that is the area where one of the canbus star connectors is located. You can peel back the carpet on top of the rear fender.
Jeep Wrangler JL Wire/Plug relocation 1721662570340-d8
Maybe that's where the canbus lines for modules underneath the vehicle plug into the rest of the network. FWIW that's the high-speed bus used for the critical stuff, be careful!
BranglerJL
BranglerJL
Atlanta
My wheel rubs on that portion when flexing even with my aftermarket liners/lift so I’m trying to see if I can move it somehow.
BranglerJL
BranglerJL
Atlanta
Appreciate the in depth response! I’ll take a look and see if it’s worth moving or going bigger on a new lift kit to stop the aftermarket fender liners from pushing on it 😂
lashlee
Knoxville, TN
I would use the rear links to push the axle back as far as you feel comfortable with.
BranglerJL
BranglerJL
Atlanta
Could you go a little more in depth on how to do this? Tried searching it up but getting different kinds of info.
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
Do you have adjustable control arms?
I believe what @lashlee is suggesting is to lengthen the control arms to push the axle further back, and away from the wiring harness/front of the wheel well. This is what I would do as well.
You do need to be careful though, because if you go too far, your driveshaft, brake lines, or wiring running to the axle may be too short at full suspension droop.
What size tires and lift are you running? Maybe someone with a similar setup can chime in to help or share the lengths of their rear control arms.
Terrymo
Terry
2023 JLURXR 3.6 ET
It’s been a while since I installed my Motobilt fender liners so I don’t recall. Does the wiring harness follow the route I’ve highlighted in green? If so it appears the harness could be moved and attached the the tab with the hole I circled in yellow. I know not all that helpful but I thought I’d try.
Jeep Wrangler JL Wire/Plug relocation IMG_1447
JL ME
JOHN
Portage Wi
2021 JL Willys ,2006 Roadking , 2008 Hayabusa
Industrial Maintenance
That plug has been the root cause of many peoples canbus issues. whatever you do with it be carful.
