Skyjacker Relocation Bracket
aug0211
Ohio
JLUR 4xe
Getting closer to pulling the trigger one a relo bracket... everything I'm reading indicates that a relo bracket IS required for 35s on anything other than a Rubicon.
The question now is just which bracket to go with.
@TTEChris (reputable forum member) indicated that his Rough Country relo bracket had to be modified to work with the Mopar tailgate reinforcement kit... I'm not planning to do the reinforcement kit right now, but I'd like the option to add it without having to modify the relo bracket IF I decide I want the reinforcement down the road. RC said they are working on a revision that will work with the reinforcement kits, but they still needed to get through their first iteration of product.
Next up, the SkyJacker above looks interesting - is that extra tab that sticks out of the bottom useful? Does it add any extra security or function? Do we know if the SJ relo bracket definitely works with the reinforcement hinges without any sort of modification? Lastly, we still don't know if/where we can by the SJ relo bracket and/or how much it will cost...
Finally, the Smittybilt relo bracket seems like it might be a good option - same price as the RC bracket and I *think* it work out of the box with the Mopar reinforcement if I want a "future proofed" system - though that is not 100% confirmed.
For me, the RC is probably out since I don't want to wait on the revision 2. That leaves me with SB vs SJ - assuming I cna get confirmation that either/both work with the reinforcement kit... and assuming that the SJ relo bracket is not more espensive than the SB option.
Any other ones to consider that I've overlooked?
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
I like the design of the smittybilt since it seems to have the "tabs" to relocate the factory bumpstops. I haven't seen/handled it in person, but I like that they included that since most people overlook that part. I think that is the key to longevity of the gate(distributing the load/weight of the wheel & tire.)
That being said it now distributes the load just a little closer to center since the relocation tabs are now part of the relocation plate and not the body.
Swanny297
Swanny297
NELA
2018 JL
In talking with skyjacker the one on my Jeep is prototype and they wanted to make a few changes - won’t be long but their production version isn’t ready yet. The extra support bolts to the rear bumper support - for a 35” tire I don’t think you need it - again they wanted to check fit on the JL - unless I was running 37 or bigger I wouldn’t think you need it. It definitely supports the weight when the tail gate is closed.
aug0211
Ohio
JLUR 4xe
Thank you, this is helpful. Sounds like SJ might not hit my timeline (hopefully.... if this thing ever arrives....), anyway, if they are still in prototype. Based on this and what @TTEChris noted, perhaps the SB is the best option for me.
