- Doug
- Jun 8, 2024
- Mt Hood, Oregon
- 2021 Wrangler Sport, 1994 Ford F350 4x4 Powerstrok
- Banned
- #16
Then you would assume wrong.Seems cool, I'm looking for off road though. I wouldn't run studded tires off road. I assume the studs would break off and/or damage the tire.
Off roading studs are less likely to have any effect, as to breaking the them off or damaging the tire, I have run studs for decades, This is the first time that I have ever heard anyone even mention breaking any studs, you should go look at some studs before they are installed, and after they are installed. Yep they will wear down, but you aren’t going to break them
Damaging the tire is a bit of stretch as well, if you’re any kind of driver. If you spin your tires until you reach a solid surface, and suddenly get traction, you can pull some out, this is most common on tires that are siped on the studded tread blocks.
It sounds as if you are visualizing studs protruding MUCH more from the tire than they actually do.
Doug
