Winch mounting on top vs inside bumper
Winch inside vs outside bumper
  • Total voters
    81
blnewt
New Mexico
Just ask @cosine he knows!
tk1700
Tom
New Mexico
2021 JLUR, 2016 Tundra, 2025 Hyundai Palisade
Where about in NM are you, I've got family in ABQ and love it out there. I'd move in a second if I could lock down a good job there
I'm in the East Mountains, about 30 minutes east of Abq just off I40. Give me a shout next time you're out this way.
JustDave
Kersey
2021 Jeep Wrangler
I've had both over the years & I have no real issues. My current is more inside and it had fitment issues on my Fishbone bumper. The Warn VR winch didn't fit well inside & I had to do a lot of cutting & grinding on the bumper to get it down in. Overall, I think I like the top mounts the best. Looks more rugged.
Jeep Wrangler JL Winch mounting on top vs inside bumper tempImageAgVpu4
rkwfxd
Rich
Whittier
Unemployed
I have the LOD with inside mount. I like the cleaner look and lower weight placement. It does stick out farther but I’ve never hit the bumper itself, the skid plate below it is pretty beat up though.
The big negative that I see now that itvis installed is nearly zero access to my winch line should it get bound up on the drum.
This may never be an issue but in the future I can see myself removing everything and using my angle grinder with a cut off wheel to create some clearance.
Caveman044
Caveman044
PNW
2022 JLURXR
I'm surprised at the responses, I figured it would be pretty evenly split.
Gadgettr1
Chip
Mass
2020 JLUR
college student
Warn Zeon 10s, Maximus-3 (mounting plate, filler plates, JL front toe loops, license plate bracket and bumper hoop), Warn cover (tight fit, should have put it in when the winch was installed). The yellow is a flexible cutting board I cut to fill the winch opening when not in use to keep salt and ice melt chemicals among other things from getting in and sitting on my synthetic rope.
Jeep Wrangler JL Winch mounting on top vs inside bumper F2C5C086-0FAF-437C-9B23-889652120C5A
Jeep Wrangler JL Winch mounting on top vs inside bumper B4D5BFA6-B942-4099-84FE-A59A3EAA7F2E
Jeep Wrangler JL Winch mounting on top vs inside bumper F33D4BBF-A040-41CB-8DB4-54D861E9A4B2
rubiRI77
scituate, ri
21 Rubicon two door. 2.0 Turbo.
I am in the minority apparently haha! I prefer outside (or top) mount.
I have no idea about other engines, but I have had no issues with air flow type issues. I have the 2.0. I also did top mount in my last two Jeeps (1999 TJ with 4.0, and a 2007 JK with the 3.8) and never had any issues with those either. However..... I also live in the northeast where we only get a few really hot days a year. I would think that your geographic location should be a deciding factor as well.
I prefer the ease of getting to the winch quickly and easily, no worries about the winch actually fitting, and being able to spool it cleanly, etc. I cover it when not in use, so I'm not worried about the rope being exposed to the elements, etc.
The tucked in the bumper does generally look better though I suppose. Although the top mount looks more utility?? All personal preference.
rubiRI77
scituate, ri
Very cool idea with the cutting board material. I may just steal that idea thank you very much!
Zandcwhite
Zach
Patterson, ca
2019 jlur
Outside.
The airflow issue is a non-issue and it's much easier to keep clean, service, remove.
I disagree that it's easier to remove when mounted on top, the bolts thread in from the bottom. Depending on the bumper, some that mount the winch between the rails allow for removal without pulling the bumper. The mounting bolts are easier to access than a top mounted winch. Of course I've never had to remove it for service, so that isn't really an issue anyway. With the factory bumper, I would have to pull the bumper to get the winch out but I'd rather use the wasted space behind the bumper, keep the weight as low as possible, and it looks cleaner anyway.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
I guess the "depending on the bumper" is the important part, because you're saying inside is easier then saying you have to pull the stock bumper, which mounts the bumper inside, which is harder.
Zandcwhite
Zach
Patterson, ca
2019 jlur
I attempted to make that clear, most aftermarket bumpers that mount the winch low between the frame rails don’t require pulling the bumper. Even with having to pull the bumper I prefer the lower mounting for the other benefits and don’t plan on pulling the winch back off ever. Not that our rigs are aerodynamic, but every little bit helps there too (maybe minuscule but if it saves me 1 gallon over the life of the Jeep that’s like a free $20)
