Eleven71Design
- Richard
- Apr 30, 2024
- East TN
- Website
- www.eleven71design.com
- 2022 Rubicon 392
- Occupation
- CNC Manufacturing.
I wanted to connect my Zeon XD10s to my Aux switch. I watched a bunch of install videos but nothing addressing the 392 engine bay with very little room to install the Warn Interrupt kit (#62132). I tried to find a spot to use factory screws as I did not want to drill and did not want to run extra wires. Best place I could find and so I used a piece of 6061 alum plate, drilled 4 holes and grabbed a spare M6 screw. Having a machine shop helps. Should have run the plate on my CNC machine to really dial it in but the drill press worked to get it going. I will draw something up in CAD and machine it later so it looks better and may be set it up in a better spot with a small offset from where it currently is. Zero interference with the hood when closed. Works great with the 15amp switch on 3 or 4.
If anyone is interested and would like an Aluminum plate to mount in the same spot hit me up. Ill machine some after drawing it up.
