mgroeger
- Mike
- Feb 1, 2018
- Southern UT
- 2021 JLUR 2.0T
- Vehicle Showcase
- 1
@grimmjeeper knows way more than me and said it best. I should have notedThe sport and sahara models come with 32s and 3.45 gears. Up until 2024 the willys had 33s and the same 3.45s. If the 32s and 3.45s are in the sweet spot then 4.10s mathematically are the sweet spot for 38s. Even if you you factor in the extra weight 37s will run around pretty similarly to a stock sport. The idea that is so critical that you need to match it to the stock tire vs gearing is easily disproven by the wide variety of "stock" ratios. Conversely the xr package comes with 4.56s and 38s and 4.95 axle gears. Where exactly is the sweet spot?
One thing don't understand though is the people who say they never see 8th gear if they don't re-gear. I have had 4.10s and 38s, 5.13s and 38s, 4.10s and 37s and always saw 8th on highway and even around town and could crawl my brains out in 1st gear beautifully.I agree, but with the caveat of not going too deep on the gears. I figured if I was spending the money I'd go all the way. 5.38s and 38s was the worst gearing combo I've run with the 8 speed and there's been a lot of them. It was in 8th by 40mph and lost 2-3mpg on freeway roadtrips where we set the cruise control at 85mph regularly. And with a Rubicon and the 4-1 transfer case 1st gear was almost useless in 4LO. My favorite combo was 4.56s and 37s for freeway speeds and all having plenty of crawl ratio in 4LO. That's such a small difference though I'll likely never regear the JT mojave as the 4.10s and 37s aren't bad and it regularly sees the 100mph limiter out in the desert so I don't need more gearing. More hp would be nice and if the 3.6L kicks the bucket I might do a 6.4L swap or the LT3. Definitely won't need more gearing with 500+ hp.
Side note: Referring to my post about the sweet spot... My understanding was the transmission is working out of its optimum zone when the gears aren't proper for the tire size, thus leading to more wear and tear on the tranny.
