Which offset JLURD
Rickeoni
Canada
2021 wrangler unlimited rubicon
I have read this forum to no end on offset, looking for some feedback. I am getting some 17×9 Fuel Convert wheels. I have a 2 inch spacer lift and 35 inch tires. Currently running stock wheels with a 1.75 inch spacer. I am torn over 1mm or -12mm offset. As far as my math goes i am running close to 0 offset with the current setup, but wondering what that will look line with 1.5 inch wider wheels. What are your all experiences with this setup.
2nd 392
Ca
With 8.5” -1mm 12.50’s tread Is ~ even with XR extensions. -12mm would be ~1/2” more poke.
Jeep Wrangler JL Which offset JLURD 2D7404FA-1EB3-4C8B-877E-354BCDEAFAA0
zouch
Berkeley, CA
XJ, JLUWD
curious; assuming your current 35" tires are the standard 12.5" width, why are you even running wheel spacers now?
Rickeoni
Rickeoni
Canada
I had slight rubbing when turning.
azbobver
Bob
Old Pueblo, AZ
'21 JLURD, '02 Ford Lightning
Permanent Vacation
On my JLURD I'm running Teraflex Nomad Split Spoke wheels:
17x8.5
Offset -12mm
Back Spacing 4.25"
Toyo Open Country R/t Trail 35x12.5x17
I have the Mopar lift with the remote Bilsteins.
No rubbing.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
@Rickeoni
My suggestion: be sure to do your homework, get your measurements correct. Where you want your tires to be regarding rubbing and poke. Get it right the first time to save headache, disappointment, and $$$. You're in the right place, get lots of advice, photos, don't make your purchase until your at least 95% sure. You can also order 1 wheel and tire to be sure of fitment and rubbing before ordering a full set.
https://tiresize.com/wheel-offset-calculator/
Best of luck my friend.
Jeep Wrangler JL Which offset JLURD Screenshot_20250630_113120_DuckDuckGo
