Wheel Locks
BillyBaroo
Bill
Fredericksburg, TX
2022 Unlimited Wrangler Rubicon
Do folks use these? I have a set from a previous Jeep. I am curious if they actually do a good job of preventing your wheels from being stolen. They one that is the easiest to steal is the spare hanging off the back. The only time it would be a concern is when traveling and staying at different hotels on my way to Colorado.
Thanks
BillyBaroo
BillyBaroo
Bill
Fredericksburg, TX
I use Gorilla locks. I buy the 24 pack so I can replace the lugs on all tires including the spare. Maybe overkill, but $125 to keep my wheels, yea, I think so.
Thanks, I will check them out.
ChuckQue
Charles
www.stayreadyoutdoors.com
2022 JLURD
Owner of Stay Ready Outdoors
Which ones did you order and from where? Thinking I need to get these considering how much I just spent on new 35’s and KMC’s.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
There have been several discussions about them here in the past. Lots of commentary about how easy some of them are to defeat. Also lots about how screwed you are when you lose the key to some of the better variants.
ECP
Peter
FL, NC, or out of the country
21 JLURD
What I like about Gorilla is you can order extra keys (they give you the number).
If the wheel lock sticks out significantly past the rim, you can use a pipewrench of even channel locks to take them off. There have ones where there is a collar around the lug so if you try the channel lock trick, it just spins.
If the thief really wants your wheels, they are gonna get them. the idea is to make it so inconvenient, that they move on to someone else's who's setup is easier to take (no locks).
ChuckQue
Charles
2022 JLURD
Yes - some of them are the stock mushroom shape, others are acorn shaped. You'll have to know what type goes with your wheel.
Thanks. I know it should be obvious but I’ve never had to pair lug nuts with wheels before. Always ordered them together.
BillyBaroo
BillyBaroo
Bill
Fredericksburg, TX
I posted this question to another thread on this subject. Does anyone know if the 24 pack fits on the XR wheel set. I assume it will but would like confirmation. Gorilla has a newer lug that has the outer part which spins unless your key is inserted and connects with the inner part. They only come in a pack of 4 which seems crazy if you want them on all of your lugs. You would end up with 4 or 5 keys to keep track of.
unsavory
Jimmy
2022 JLUR XR 2.0T Auto, 2019 JLUR V6 Manual (sold)
What is the point of one on every lug? If one can be defeated, then they all can, no?
Also, check out Advanced Wheel Locks. Someone else mentioned these on these forums, and I picked up a set. Very impressed with their construction.
BillyBaroo
BillyBaroo
Bill
Fredericksburg, TX
Having a locking lug on every wheel will slow down anyone trying to steal my wheels. They will likely go on to another Jeep. The locks are by no means theft proof, just deterrence.
ECP
Peter
21 JLURD
I presume its a standard Mopar lug, so yes (and they have both 24 packs in both styles). You can double check the Part Number.
If you really want the one that only comes in a 4pack, I'd suggest contacting a dealer that has them and saying you want matching keys. So one key would fit all lugs. although if you go to 24, I doubt you'll need the spinning ones - if you're in that type of hood, they'd probably take the whole Jeep!
BillyBaroo
BillyBaroo
Bill
Fredericksburg, TX
Thankfully I do not live in a high crime hood. I am only concerned while traveling. Now the only question is black or chrome? My wheels are black with chrome lugs currently and they look fine but black might look even better.
Similar threads
