What is this?!
swanny2369
Kris
Denver CO
22 JLU Rubicon
Ok smarty pants’s,
What in the Sam hell is this bracket and why is it welded to the frame of my brand new rubicon?!
Jeep Wrangler JL What is this?! AD1790B9-B857-496B-887B-8A66B1057D05
Jeep Wrangler JL What is this?! D410C385-3CB2-4660-A691-15985EA94BA7
Jeep Wrangler JL What is this?! 59A9B9C0-F863-49F2-8B09-35DE0E55614E
hoag4147
Colleyville, TX
2022 JLUR XR
Word is added to assist with roll over crash test. Causing all kinds of issues with step sliders
gsbrockman
Greg
Sand Gap, KY
2023 Dodge Challenger Scat Pack Plus A8 & F8 Green
Owner / Operator Brockman Hauling, LLC
Sure it’s not bolted on?
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
I believe the consensus is it’s a crash bar. It’s supposed to help prevent the wheel from entering the cabin in a collision.
Should be bolted on and removable. The Broncos have something similar, but people remove them all the time to fit bigger tires.
swanny2369
swanny2369
Kris
Denver CO
22 JLU Rubicon
It is bolted and welded. Three 18mm bolts holding to a bracket inside the frame then two more behind the slider. Only noticed the weld after I couldn't get it off after the bolts we removed. You can see the vertical weld behind the hole holding the bracket to the frame. I didn't plan on getting the grinder out on this jeep just yet...
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I asked the guy who installed my RSE rock sliders last week if mine were welded on and he said no, he just took out the bolts.
JLURD built May 17th if that matters.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Worlds strongest mudflap :)
Lol, would almost function as a mudflap, but not quite wide enough coverage I think.
So, beside slider fitment issues, is this also going to cause fitment problems with front mudflaps as well? Kinda hard to see, but it looks like it's blocking the usual mounting location.
DaltonGang
Doesn't Play Well With Others
It must be something new, to the newer Wranglers. My 2018 doesn't have it.
Jeepmarkjl
Chicago
2021 Wrangler JLU Rubicon
Marketing
I can help you out here. Those brackets are for your display case mounts. So if you’d like to put your Jeep in a giant glass case or mount it to a wall, Stellantis has thoughtfully provided the pre installed brackets. It’s plug and play. The Dutch think of everything.
Jeep Wrangler JL What is this?! 2D9C3B82-F0B7-438F-A45C-D172C16AFFB8
Petey
Pete
Miami
2020 jl sport manual
European vehicles require them so i too wonder how that problem is resolved over there if it is one.
Also to me it seems like something might catch on that in an offroading situation. Create problems
  • Like
Reactions: AFD
gsbrockman
Greg
Sand Gap, KY
I believe you are correct. My 2021 does not have it.
Does this mean our 2021’s just went up in value.....even MORE? ?
