Weight distribution hitch questions
Valpo Jeep
Doug
Valparaiso IN
Well it looks like our Class C RV will likely get totaled from a tree branch falling on it. $8,000 to $10,000 for a new roof and its a 2005 so 21 years old and very low in value as a result.
We enjoy camping and are looking to go to a teardrop style camper and tow it with our 2018 Sport S JLU. I am limited to 3,500 lbs and found a possible candidate that will be right at that if I do not overload it. I know the drivetrain will handle it without question as the same drivetrain is in a Gladiator with a higher tow rating. I have found a potential candidate that is a teardrop style but taller like a travel trailer so you have room to stand up in it.
My question is at what weight do you all recommend stepping up to a weight distribution hitch system? I have read a recommendation to use one if your trailer exceeds 50% of the towing vehicle weight. That means anything over about 2200 lbs will will need a WDH system with a JLU.
Something like this for trailers: This particular trailer is about 18-19 feet long, 8 feet wide, and about 9 feet tall.
Jeep Wrangler JL Weight distribution hitch questions 1779823513621-1s
Grayhound
Michigan
Jlurd
I used a wd hitch for this little guy. The jeep is so light and suspension so soft I thought it best.
Jeep Wrangler JL Weight distribution hitch questions IMG_20200809_113109_Original
JeepinPete
Pete
PA
'19 Mojito JLUR
Mechanical Engineer
Really depends on the tongue weight of the trailer in question and what suspension your Jeep has. I tow a trailer the exceeds the specs and my Jeep handles it fine. Its tongue weight is ~500 lbs so I use a Reese setup that came with an old travel trailer I had. It is necessary and works well.
Look on CL or marketplace for a used hitch, they go for pennies on the dollar.
shooting4625
Colin
Coming soon 2023 2door wrangler Rubicon
I tow this tear drop, it is around 1100lbs limit for the 2dr jeep is 2000lbs, tows great does not even know it is there
Jeep Wrangler JL Weight distribution hitch questions IMG_6808
F4Flyer
Littleton
2024 Rubicon X
I would get a WD hitch for the R-Pod. The Jeep is not great at towing, at all. The WD hitch will make it much safer
