Valvoline Restore and Protect Question
CarbonSteel
Maybe someone can do some long term testing over multiple oil changes submitting samples to Blackstone Labs for analysis.
I wouldn't use Blackstone if you are looking for accurate test results including fuel content and TBN.
Use Horizon/Polaris instead.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
How does Horizon/Polaris oil test cost compare? Have you done side by side testing between the two?
I was thinking Blackstone would be okay for trend analysis.
CarbonSteel
Yes, I started with Blackstone and have 30+ tests with them before switching.
Blackstone does not use the latest ASTM test methodologies, their fuel content test is very subjective (visual flame test versus gas chromatography), they are not ISO 17025 certified, they charge for TBN test separately, and they cost more than Horizon/Polaris.
Horizon/Polaris is superior in every way possible.
dragoneggs
Seabeck, WA
I’m on their website and I don’t see an easy way to submit samples. What am I missing?
CarbonSteel
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
As an update.... I am a few hundred from 2500 on 2nd oil change. Checked oil visually and it is as dark as the original oil that was in vehical when purchased with 5k on its life. So with that said, it seems to be mostly done with cleaning the engine. I figure on the next oil change, another run with Restore and Protect should get things close to squeaky clean. At 91,000 on odo still does not drink a drop of oil. Also running hard time to time after 2k on Restore and Protect when warmed up will loosen the residue on and around rings quicker.
I'm pretty sure I'll never need to use another oil. The price for a 5qt jug should be higher on this oil... just hope Valvoline does not figure it out. Ha!
Can't wait for my next oil change... will send out my 5 samples for analysis at Blackstone.
YBABRAT
VIRGINIA
azwjowner
Phoenix
I don't mind your posts, but this one takes the cake. AMISOIL is not Restore and Protect, nor can do what this product does. Unless you have tried it or have questions then by all means. Else peeps here on this thread my block you as a bot.
Perhaps you should have read his post in its entirety before responding…
roaniecowpony
Retired Engineer
He stated that he buys his oil analysis kits pre-paid from the Amsoil site.
Jeep Wrangler JL Valvoline Restore and Protect Question seth
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
Easy there fella....
PunksJL
PunksJL
Paul
Colorado Springs, Colorado
2025 Rubicon X 2.0T Bright White
Since I've already mentioned Lake Speed and his company Speediagnostix in this thread, they also do oil analysis. I don't know how they compare to some of the other oil analysis companies mentioned here but it might be worth a look.
SPEEDiagnostix
CarbonSteel
ROFL...I take it you can read?
Amsoil sells the UOA kits that @dragoneggs was asking about.
Damn man...
As far as Valvoline...Group II+/III oil owned by Saudi Arabia... color me unimpressed.
Pape
Quebec
JLU Sahara
SPEEDiagnostix
Wonder the same, look to be super friendly report. unfortunately living in the great white north I'm afraid that my oil sample will be summited to vigorous border check... :headbang:
roaniecowpony
Retired Engineer
Full cavity inspection?
