Two USB-C ports on dash MOD?
donmontalvo
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
Terrymo
Terry
2023 JLURXR 3.6 ET
I had my console panel removed earlier today and noticed the Mini B plugs. My goal is to swap out the USB-A port for a USB-C port, without losing CarPlay capability on the top (“#1”) USB-C port. Wireless CarPlay is a joke from what I’ve seen.
I think I will run a Powerwerx dual USB-C QC 4.0 connector to the front of the center console storage area, facing the cupholders. Will post whatever I come up with.
On a side note, funny how you seem to have your Accessory Port wire taped off with blue painters tape. I removed my Accessory Port so I could install the Redarc dial…but I used black electrical tape to isolate the same wires. :)
I stole the pic from @THAW
wwtucson
William
Thousand Oaks
2023 jeep wrangler Rubicon
To add extra USB outlets I installed a splitter cable on the back of the cigarette lighter. Then powered a dual USB outlet under the steering wheel behind the plastic panel.
Jeep Wrangler JL Two USB-C ports on dash MOD? Screenshot_20250628_065111_Chrom
Jeep Wrangler JL Two USB-C ports on dash MOD? 20250225_135454
Jeep Wrangler JL Two USB-C ports on dash MOD? 20250225_132215
Mojito Mojo
Doug
Apache Junction, AZ and North Mankato, MN
2018 Mojito Rubicon JLU, 2004 Corvette convertible, 2015 HD Road Glide, 2014 Indian Chief Vintage
My plan is to put one of these up in the top of the dash in that little cubby. I need a USB-C outlet up there to power my tablet running GAIA when I'm traveling/off-road.
Nice looking Jeep!
Jeep Wrangler JL Two USB-C ports on dash MOD? IMG_0572
Cartman
ANDREW
Slovakia
Jeep JL Sport+ 2d 2023
Where is the black USB connected? The gray ends in the radio but the black one is missing in the bundle but the connector in the position in the radio is empty.
Gregj
Greg
West Texas
It might feed the one in the console and rear seat.
Gregj
AmericanPatriot100
Kitsap Co
2025 Wrangler Sport JL
My wireless CarPlay works flawlessly! And in the center console at the back there is another usb-c port. At least in my ‘25.
Gregj
Greg
West Texas
A slightly cheaper alternative is This one
Gregj
RatZero
Canada
2024 Willys JLU
Manufacturing @ Stellantis
The splitter Cable mentioned above is the best easiest option for adding additional ports. You could then install the ports anywhere convenient, even removing the Media hub and using that area for ports. If you have Aux wires, that's another option for powering ports with control on when they are powered.
THAW
Foster
23 JL4DrRubicon
The painters tape was used to prevent scratches.
