TPMS Sensors
Wildmank99
Maryland
88 xj and 18 JL rubicon
Military
Still cannot get my OEM sensors to work off the stock wheels with only 180 miles on them. At this point I am getting ready to order some aftermarkets.
That’s weird
LABLUE
Craig
MI
2018 JLU, 2019 Ram 1500 North edition
CDJR Master Tech
I had my new wheels installed yesterday and they removed the sensors from my stock tires and placed them in the new. The sensor warning light will not go out. Does this take time for it to adjust or is something wrong? Thanks in advance.
Is the light flashing when you start the Jeep or is it on steady? If the light is just on(not flashing) then check the tire pressure make sure they are set to the door sticker.
TroyG2015
Troy
Georgia
2018 JL Sahara
It flashed when I start the Jeep and after a few minutes of driving it goes to steady. I have all the tires set to 37 PSI,
TroyG2015
Troy
Georgia
2018 JL Sahara
I changed the wheels and tires and removed the factory sensors from the 5 stock wheels
LABLUE
Craig
MI
CDJR Master Tech
They may have damaged a sensor. :angry:
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Oh...BTW, the eBay website link also says it won't work on a JL. We'll see. I figure for $55, it's worth a shot. They're supposed to be here by next Saturday. I'll try and remember to update the thread.
Well if they dont work then I don't own two JL's.... I have a Rubicon and my wife has a sport with these sensors installed and working :beer:
AZJLU1100
Lee
Phoenix, AZ
2018 JLU Rubicon
I bought 35” wheels and used the factory sensors. My front left was not working and the dealership reprogrammed it. It worked for about 10 miles and went out again. Two weeks later, the front left started working and now the left rear is not working. The dealership said it’s not covered under warranty because they are aftermarket tires. I disagree because they are the stock sensors. Am I wrong on this? Anybody else dealing with sensors going in and out? Uuugghhh
  • Like
Reactions: J0E
BillyHW
CAN
I just hate it how 99% of dealers give the other 1% a bad name.
phatjoe
VJ
Austin
2019 Ram Powerwagon, 2019 Wrangler JL Rubicon
https://www.ebay.com/itm/5-NEW-OEM-56029398AB-68241067AB-CHRYSLER-JEEP-DODGE-TPMS-TIRE-PRESSURE-SENSOR/181749105026?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
$55 for the set of 5
Put these on my JLU Rubicon, and they worked great. Have another set sitting here that I ordered for my wifes JLU Sport.
Thanks "TTEChris". Last week, I purchased these sensors off of ebay. The sensors were installed and work perfectly! The BEST price around for 5 sensors, you can't go wrong. :)
AZJLU1100
Lee
Phoenix, AZ
2018 JLU Rubicon
I switched out the sensor that was not reading and all is working perfectly. I got my work down from Outlaw in Scottsdale and they were great.
phatjoe
VJ
Austin
The sensors TTEChris recommended off eBay worked flawlessly. No issues.
Hey, great looking jeep! Just curious, what wheels are those?
JoseTorro
JT
Ontario, Canada
Rubicon JL 4 Door
Mine just came in but the serial number that's suppose to end in AB ends in AA, it better be the right part. I won't have them installed for another week or so.
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
I had my OEM wheels and tires swapped out along with sensors, the sensors read pressures but the idiot light won’t go out, raised pressure from 32 to 36 and still lit. The idiot light flashes on startup and sounds 1 ding then after a minute or so goes steady, like I said all pressures are reading and compared with pocket air gage and the numbers match but the idiot light just glares at me and laughs, I never had discount tire scan the sensors and the advised all read so have no idea what’s going on but have a Taser coming
GRAK
Out West
JL Rubi, Corvette
Annoying, new OEM sensors or one of these cheap ones from this thread? I just bought the ebay ones, see how they perform soon
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
They say OEM... I've used them on 4 JL's now, and countless JK's without any issues(Knock on wood, I have another set coming for my new wheels)
