TPMS on the new wheels
Willywhitie24
NOVA
2024 4door Willys
Im putting a new set of rocktrix wheels on my 2024 willys but keeping the stock tires. Can the tpms on the original wheel be put on the aftermarket? One shop quoted me $600 because he said new tpms have to be installed and the original ones cannot be used.
2nd 392
Ca
Yes they should be, TPMS just screws into the valve stem. I found out when the short valve stems supplied with the new wheels wouldn’t work and available longer TPMS capable ones were used.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Did the shop specify why they wouldn't fit? And why the replacement was $600? I'm pretty sure this is what you've got ($32.80 each), but @AllMoparParts.com can verify.
I'd definitely get a second opinion.
jadmt
jeff
montana
JP52
Walnut Creek, CA
2022 JLU Rubicon XR
I bought new wheels and tires from America's (Discount) tires and they did not charge any extra to swap the TPMS sensors from my old to my new wheels and remount the old tires on the old wheels.
Willywhitie24
NOVA
2024 4door Willys
So with my 2024 its shouldnt be a problem right? I have an appointment tomorrow at a local tire shop will charge $40 each for all 5 including swapping the tpms.
2nd 392
Ca
Swapping the TPMS is a couple minutes to unscrew and re screw. Tough Job :whew:
jadmt
jeff
montana
correct, $40 a tire is reasonable. I am curious what wheels you are going with that made another shop say you could not swap the oem sensors in.
John VonJeep
Middle of Nowhere
Many
That price is insane. At the outer bleeding edge, this job should cost no more than $60/tire, or $300 total.
$150 would be more normal.
$600 is PT Barnum territory.
Willywhitie24
NOVA
2024 4door Willys
rocktrix rt112
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
