Too much bounce
Duff
Brandon
2018 Jeep Wrangler JL
I just bought a 2022 Wrangler everything is stock. I’ve had to two previous Wranglers, 2020 and 2018 so I’m familiar with the ride. The 2022 has a lot more bounce on any bump I go over, it’s not affect handling, just so much more noticeable than my 2020.
I’ve put on new GY Wrangler tires, had the balancing done at a specialty tire and rim shop.
I have no idea if the previous owner had larger rims and tires and just returned it to the stock size at trade. I’m wondering if the bounce is due to a caster adjustment? Would the caster need adjusting if the previous owner had run larger wheels? What would I be experience if this needs to be done. Or is it in need of new shocks? (31,000 miles)
Anything else I can look at?
Thanks for the help.
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
Caster is not causing your problem. Wheel size has nothing to do with caster. A suspension lift needed to clear larger tires may require caster changes.
Hucke_250
Ohio
2018 Unlimited Sport
Did you notice the bounce prior to the new tires? What load rating are your new tires? I’d inspect the shocks for possible leaks.
Wellington Wrangler
Duff
Brandon
Yes the bounce was noticeable with previous tires.
New tires are Goodyear Wranglers with Kevlar 275 70 R18. Same tire I had on my last Jeep and they preformed well.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
At 31k miles, your stock shocks are about worn out. Visually check them, you may even find one, or more leaking.
Terrymo
Terry
2023 JLURXR 3.6 ET
The factory shocks are marginal to begin with in my opinion. I’m curious about what tire pressure you run as well.
azjl#3
North AZ
Tire pressure?
aeonixx1001
Kim
Arizona
2020 Jeep JL
Shocks, Caster wont cause bounce. The downward inertia is not being dampened by the "Shock" absorber. Upward motion is freewheeling. Results bounce all over the place....Take care and good luck, let us know..
Blacksport
Ft Lauderdale
'25 Wrangler Sport S, 3.6/manual trans...'23 Corvette C8...'25 Yamaha XMAX
Because of the solid (live) axles, there's no camber & castor adjustment on Wranglers, only toe adjustment on the front axle. You can do that yourself, with a friend and a tape measure. Set the toe just slightly in, no more than 1/8", which will reduce "wondering"...
Pape
Quebec
JLU Sahara
I echo the other who have say: tire rating and pressure
