jellis4148
Okay. I’m finally going to get tons, but I went down the rabbit whole of research and narrowed it down to Currie or Dynatrac. For sure doing 72.5” unless someone can give me a solid explanation of why I shouldn’t. Here’s my questions.
1. Air or E-locker. Supposedly air is superior. I like the E-locker but have read they has issues a few years back with teeth breaking on the locker. Currie says it’s because people wire them into the factory locker switches and it doesn’t put out enough or constant voltage and that causes problems. Currie will void warranty if do wire them that way. Would like to hear from people that have “abused” the e-locker and see if you would get them again or go to air.
2, if they were free which one would you take, Currie or Dynatrac? Both customer service seems very good. If I did dyna I would get the 60/80 just because. Currie seems solid. One question on Currie. They have a load bolt on the front axle. How do you adjust it and can it be an issue later on? I like Currie still being somewhat family owned. I know Dynatrac is owned by east coast gear supply along with fusion, and Yukon. I don’t want fusion axles. I thought I did, but after speaking with several people, I’m out on them. Seriously considered Dana, but the don’t make a 72.5” axle.
Thanks for the help in advance. I know this subject has been beat to death. I’ve been saving for 4 years and it’s a lot of money. I want to get the best I can, and also the right options that I’ll have the least issues with.
