Tire size?
Nokones
Kenny
Sun City West, AZ
I am running Mickey Bajas 315-70-17s on Method 106 Beadlocks with no problems on my 23 Wrangler Rubi 2 Dr.
Jeep Wrangler JL Tire size? 20241208_145845
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
It's rough for me to keep up with sleep these days, let alone everyone's jeep. 🤣
I hear you, brother. I haven’t slept since Christmas night. Seriously.
2nd 392
Ca
I have had to use wheel spacers (2”) when I bumped up to 35x12.50 on stock 7.5” wheels. At full lock I was rubbing the LCAs without them.
@WillIeB
@Wabujitsu used 2” or ~51 mm spacers so -7 would absolutely work. If the entire 2” wasn’t needed then less like the common 0 offset likely would.
Wabujitsu
Sarasota, FL
Retired US Army
@WillIeB
Mike, I’m thinking 33x12.50s would not require the same spacers/offset as my 35x12.50s.
2nd 392
Ca
John, did even your 35’s require 2”, I would attempt to keep it at ~0 offset so the tread doesn’t stick out past XR extensions. Or similar aftermarket for other fenders.
AskBin
22' Willys EcoDiesel
im on 35x11.5's, non rubi, stock willys wheels. everythings pretty tight as is now. Tires contact something somewhere sometimes, i have yet to take off my sway bars and see whats doing what under full articulation, im just getting old and lazy. 12.5's will rub for sure on stock wheels
billjr
Norwalk, Ct
2022 Wrangler Rubicon eTorque
Retired Telephone Plant Engineer
I was reasonably certain a 12.5" wide tire on the factory wheel might rub. It might be OK on the Rubicon with wider axles.
They (33x12.5x17) do work on my 2022 Rubicon on the stock wheels with no rubbing.
yokramer
Snark Incarnate
On a set of proper offset wheels you will be fine with 12.5s.
