Tire Size VS Odometer Accuracy
Jeeps Luv Mud
Greg
North Carolina
2001 Jeep Wrangler Sport
Hey fellow Jeepters,
I bought a new (to me) Jeep, 2001 Wrangler Sport (TJ) 4.0L, It had 31x10.50 15 tires on it.
How do I calculate the actual mileage driven? I know different packages come with different stock tires.
I've heard you can change a small plastic gear in the trans. but is there a formula to do it?
Someone else said to flash the computer with the new info., I'm not sure my 2001 has that type of chip.
Thanks for any ideas :)
Jeeps Luv Mud
Jeeps Luv Mud
Greg
North Carolina
This site helped me already!
Upon posting my question several similar threads popped up one with the answer I needed!
From Lustmord in Los Angeles, Thanks
C.Sco
2023 4xe Rubicon
This being a JL forum (2018-2025 models), most of us won't have a clue how to do anything on a 2001 TJ (although I'm sure some members here incidentally own or have owned one)
I can't help you with the computer reprogramming or the small plastic gear in the trans, no clue about either of those things in a TJ. But for converting the odometer and speedometer readings is pretty easy. I use this website:
https://tiresize.com/calculator/
Click the "Tire Comparison" tab, and enter the OEM tire size, and your current tire size, and it will give you all the info you need.
2001 Wranglers came equipped with any of the following tire sizes:
  • 30x9.5r15 (Sahara and Sport) = 30.0" diameter
  • 205/75r15 (SE) = 27.1" diameter
  • 215/75r15 (SE and Sport) = 27.7" diameter
  • 225/70r16 (Sahara) = 28.4" diameter
  • 225/75r15 (SE and Sport) = 28.3" diameter
Yours is a Sport trim so it was either 30.0", 28.3", or 27.7" diameter originally. Hard to say which one without seeing the original build sheet / window sticker. Your current tires are 31" diameter.
Jeeps Luv Mud
Jeeps Luv Mud
Greg
North Carolina
Thanks, I am new here and hunted on the site for a place to asked about
tires and this was the thread area that came up. Thanks again :)
There are other multi-model jeep forums and even a TJ forum or two out there. You might get some good information on this and many other things about your TJ.
Jeeps Luv Mud
Jeeps Luv Mud
Greg
North Carolina
Thanks,
Does the site have a TJ area?
If it does, I haven't found it yet.
Jeeps Luv Mud
Jeeps Luv Mud
Greg
North Carolina
Thanks Man, when I signed up here I thought it was a multi-Jeep forum.
Keep on Jeep'in :)
C.Sco
2023 4xe Rubicon
Jeffy56
Payson, AZ
2018 Wrangler Unlimited Sport
Old school. Yes there are different gears for the speedo cable output. You'd have to research that particular Jeep model transmission. Amazon/Autozone/O'Reilly's should have a "set".
Calculate real speed by time to do one mile @ 60 MPH or a phone GPS with options program. Calculate error % vs number of gear teeth. Change and re-check. I use "GPS test" phone app.
https://play.google.com/store/apps/details?id=com.chartcross.gpstest&hl=en-US
Fun when flying. Doesn't need a data connection.
Jeep Wrangler JL Tire Size VS Odometer Accuracy Screenshot_20231209_070230_GPS Test
Jeeps Luv Mud
Jeeps Luv Mud
Greg
North Carolina
For you guys not being a TJ site I got lots of help anyway :)
I used a GPS app to validate the tire size recal on JSCAN. Worked great on a straight stretch of hwy.
