Tire Pressure TPMS accuracy...?
RubiconRider
Deen
Philadelphia
Jeep Wrangler 2016 Rubicon
So I lowered the pressure in my tires to 37 PSI today, but my TPMS still reads them at 40 PSI.. Is this normal?
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
It takes alittle bit for the pressure to correct itself
TheLion
Seattle, WA
2018 Sahara JL
It's pretty close to being accurate based off the arb tire deflator I used. One or the other is accurate, not sure which. However they are only about 1-2 PSI off from each other - not enough for me to care either way
Swanny297
NELA
2018 JL
Takes a bit to level out - TPMS sensors aren’t very accurate most are about +/- 2psi (this is what they were typically spec’d at for ones we used on Colorado/Canyons)
cjaama
Albany, NY
2019 JLUR
Digging up an older thread here to solicit further opinions.
I just picked up my JLUR Friday. My TPMS is reading 41psi at all four corners. I have a cheap digital gauge that reads 37.5 and two stick-type (looks like a pen) gauges that give different readings, one closer to 40 and one somewhere in between.
Can anyone say how accurate the TPMS is and how they’ve determined its accuracy? I'll probably end up just lowering it a couple to put it somewhere in the middle.
COSJL
Colorado Springs
2015 WK2, 2019 JLR?
For me it was within 1 psi of the cheap gas station pressure guage. I have already verified this guage to be within 1 psi of my Grand Cherokee tpms readings, so I think they are fairly accurate.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@COSJL
@cjaama
I would use the TPMS sensor reading on the evic as an approximate.... use to eyeball quickly, to get an idea approx what the psi is.
There is no substitute for checking psi in tires in the early AM, when it is cool out ... before you drive the vehicle.
Do use a known to be accurate gauge.
In regard to your JL's TPMS:
How does the JL/JLU know which tire/rim/wheel is where .....
Well, there are 3 sensors on the chassis that monitor the 4 TPMS Sensors found on the 4 tire (rim) positions.
Info from the 3 chassis sensors is transmitted to the Wireless Control Module. There is no need for a 4th chassis sensor as the computer uses the process of elimination to determine the fourth tire location.
Yes, your JLU/JL knows exactly which rim is where, usually within seconds of a tire rotation for example. Yes, It's all done automatically.
There is a TPMS sensor in the factory mounted spare but it is not read by a chassis sensor/ considered by the computer until it is placed in one of the 4 tire positions.
jerseymike
Allentown, NJ
2018 Wrangler JL Unlimited Sport S
I always think they are more accurate than the manual guage but not 100% sure
WranglerMan
Will
Greenfield Indiana
My tire gage is digital so it’s more accurate the the EVIC display
RMojitoJL
Skyler
Las Vegas, NV
2019 Jeep Wrangler JL Rubicon *Mojito*, 2019 Jeep Grand Cherokee Altitude, 2019 Honda Civic Hatchback Sport
Loan Officer
my TPMS shows 1-2lbs more than measuring at the valve myself. idc what it shows on screen, as long as i know I'm running what I need to be.
