Tire rotation miles
Al G
AZ
2020 Wrangler JLU
My new tires had 2500 miles on them when I left on a summer trip towing the Jeep behind my RV. By the time I get home I'll add about 2000 miles of driving and 3200 miles being towed. Is almost 8000 miles of wear too late to include the brand new spare int the rotation? In hindsight I should have done a 5 wheel rotation before I left but too late now.
My intent when I put on new tires was to do 5 wheel rotations to get maximum life. Even if I have to go with 4 wheel rotations the tires will probably age out before they wear out.
Operative73
Christian
Pittsburgh PA
2020 Wrangler Sport S/2017 Softail Breakout
I don't think the miles on the tires between rotations matters as much as the size difference from wear those miles create. I don't know what the size difference allowance is for different diameter tires across our axles. I believe you can have a difference of 4/32" with no issues.
I typically do a five tire rotation at oil change time. I've never measured mine to see how much of a difference they have.
Reinen
2021 Jeep Wrangler JL Rubicon
You do realize you can do a 5 tire rotation at any time using only the jack in the Jeep, right?
Spare to rear passenger
Rear passenger to front passenger
Front passenger to driver rear
Driver rear to driver front
Driver front to spare
It's only the 4 tire rotation that requires a shop lift.
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
Or jack and a jack stand
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
I have ALWAYS done my 5 tire rotation every other oil change … approx. 6,000 - 8,000 miles and have been fine.
You will be fine!
Al G
AZ
2020 Wrangler JLU
Not really something I want to do while I'm traveling. I don't like using the Jeep jack unless I have to.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
8,000 miles is no big deal. The difference in tread depth isn't much at that point. Even 10-15,000 miles isn't a big deal.
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
Good and timely info for me, as my Jeep will be doing duty as a Toad soon. I do "5-tire" regularly, and never thought about the added mileage that they will see while I'm away from home.
This is one of the reasons that these forums are worth reading!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I wouldn't worry about it, but just in case, moving the spare to the front will mitigate any push you may get from having slightly different diameters on the rear drive axle.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Push? Only when locked, right?
GATORB8
CLT NC
Not in my experience, I tried to rotate in a new one after a sidewall tear, I'm probably was more than 10k on the others.
Makes sense since the outside tire in a turn would get more power since it's traveling further. The larger diameter slightly mirror that.
Al G
AZ
2020 Wrangler JLU
I did the tire rotation today. There was less than 2/32 difference between the new spare and the tires with miles.
TJDave
Eastern WA
2018 JLUR Rubicon
Motorized toy collector
I've been flat towing Jeeps behind motorhomes since 2006. 4 different Jeeps, 3 different motorhomes. Keep a close eye on the driver's front tire. At the first sign of abnormal wear/cupping, rotate. They all did it. 33, 35, and 37 inch tires. MTs worse than ATs. All Jeeps were within alignment specs with no wobbles. I blame it on the crown of the road. Jeep wants to track towards the shoulder while the motorhome pulls it straight. Some may disagree, but that's my story! Happy camping.
Jeep Wrangler JL Tire rotation miles 20250521_125820
