Tire pressure advice
AnARcHy
Bob
North Carolina
2018 Jeep JLU Sahara, 2003 Toyota Tacoma, 1990 Toyota Truck, 1998 FLSTC
Firefighter
I have Cooper AT3 XLT 275 70 18 tires on my 18 JLU. The dealer has them inflated to 50 psi, and that seems excessive to me. Any suggestions for correct pressure?
DesertsJL
JLUR
Way too high. At most they should be 37 as is recommended by Jeep, or slightly lower based on the slightly larger size. That must ride like a tank at 50psi.
AnARcHy
AnARcHy
Bob
North Carolina
Firefighter
It actually doesn’t ride bad. They are 10 ply tires, but I’m concerned about tire wear. I read posts about doing the chalk test, but don’t really have a good place to do that. Was hoping to find out what others are running in similar tires.
DesertsJL
JLUR
I ran my 33’s at the recommended pressure of 37psi. I lowered my 35’s down to 30. I’m putting 37’s on in a few days and will likely run 28psi or so depending on how even the “chalk test” wear pattern shows. Your tires should measure out 33.7 or so based on the tire calculator. Given that they are also a heavy 10 ply, if it were me, I’d start around 35 and adjust from there. But it’s entirely up to you to find that sweet spot that you like.
beaups
Sean
Ohio
2020 JL
You don't need chalk to know 50psi is way too high. Even the 37 on the placard is likely a bit high for those tires.
AnARcHy
AnARcHy
Bob
North Carolina
Firefighter
I’ll drop them to 35 tomorrow and see how it handles. If I can find a good place to do the chalk test, I will do that. Thanks for the info!
AnARcHy
AnARcHy
Bob
North Carolina
Firefighter
The tires are rated to 80 psi. I used to own a Dodge Ram 2500 Cummins, and those were the type of tires I ran on it, so I know they are way too much for the weight of my Jeep. I just needed some advice on where to start for the tire pressure. Thanks for the reply!
DesertsJL
JLUR
I use my driveway and roll back and forth a few times, but any good smooth section of concrete will do it. You don’t need to drive a long distance in order to see how the chalk is wearing off.
Kluk Ztopolovky
Kluk
Toronto
Wrangler JL Sport 2dr Sting Gray manual
Tires are an important component of the overall suspension system on any vehicle . Correctly inflated tires absorb most of the road impact and by keeping your tires over pressured you are not extending the lifespan of your shock , bolt joints and all the rest of the suspension set up plus you are getting bumpy hard ride.. I rather keep my tire pressure gently under pressurized than too high.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Do a chalk test or 10% rule but as stated 50# is way to high
blnewt
New Mexico
Just ask @cosine he knows!
I run my 10 ply Pats at 30 psi, seems to be the sweet spot for these tires.
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
A friend at 4 Wheel Parts installed my E-rated BFG 275/70R/18 KO2's 33,s BFG Tech says 41 PSI. He had me drive home and feel how the 41 PSI rode and then lower to 34 PSI. Much softer ride at 34 PSI, that's what I keep now.
WranglerMan
Will
Katy Texas
Gas Pipeliner
10% rule?
yes 10% rule.....basically you can either use the TPMS sensors or a tire gage but obviously the TPMS display is easier but you observe cold air pressure by either means and then drive for 20-30 mins and a good speed to warm the tires which in turn raise the air pressure and the goal is to not go above 10% of the cold psi reading
Here is an explanation of a bike tire but the concept is the same http://www.allendesigns.com/personal/TenPercentRule.htm
I just chalk test mine and it’s very close to 10% and I get very even contact
