Tire Pressure
Bluegoose972
Rick
Belton, TX
2018 JLUR Firecracker Red, 1966 Mustang Convertible (rebuilding)
Have 37x12.5x17 Toyo's on 17x8.5" wheels. Pressure was set at 40 psi, but can see that there is uneven wear. What pressure are you guys running with a similar setup. Thinking of dropping another 5 psi to 35 psi and watching the wear pattern.
Amric
Michigan
2003 TJ Rubicon, 2018 JL Rubicon
28psi
kkuntz01
Kevin
Mount Juliet, TN
2018 JLU Rubicon, 2014 Ram 2500 Crew Cab
Every vehicle is going to be a little different as to what PSI to run. The best way to determine what PSI will be best for your vehicle will be to do a chalk test on the tires like @FatBoy01 shared below. I won't lie, it can be tedious, but it will tell you where you need to be.
OnlyOne
New Mexico
2021 Gladiator Overland Diesel
About 28-30 psi should get you where you need to be.
kkuntz01
Kevin
Mount Juliet, TN
But a chalk test will get him to exactly where he needs to be without spit balling...
OnlyOne
New Mexico
Been there. Done it. 28-30 is pretty basic on 35’s and up. Just trying to help him speed things up. Tire pressures are going to rise and fall all day long. 1-2 psi difference with a chalk test isnt going to get anything exact.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
I run 25psi cold in my E-Rated 37" Coopers, and every time I tell someone they look at me like I'm nuts..... I've been doing this since 2012 on all my E-Rated tires(17" Wheels), and not once have I run into any issues. The chalk test shows that I can even go lower, but I'm content with slightly uneven wear at 25-27psi(depending on outside temperature.) There are formulas online that help you calculate tire pressure based on your GVRW & Tire Load Rating @ max PSI on the tires. When using that calculation it tells me to run 26psi on my Coopers when my vehicle is fully loaded(Which it rarely is, but I factor in bumper/winch weight etc.)
Early on I even used a Temperature gun to make sure my tires weren't overheating when on the highway for over an hour...
BillyHW
CAN
The Rubicon stock LT metric tires of LT285/70R17 at the door jam recommended pressure of 37 PSI means each tire can carry a load of 2,189 lbs. (via linear interpolation from the table).
The Toyo LT high flotation tires of 37x12.50R17LT need a pressure of 25.6 PSI to bear the same load of 2,189 lbs. (via linear interpolation from the table).
Here are the tables I used:
http://octopup.org/img/car/tires/Ru...intcmp=na-pagena-article-data_reason-external
I'm not saying that's necessarily the best pressure to be running your tires at, but that's an informed starting point (i.e. lower bound) if you want to make sure you haven't screwed up all the load bearing characteristics of your vehicle.
Someone please check my math.
PaPasJP
Gainesville, FL
Exactly and couldn't have said it better.
BillyHW
CAN
Hey, looks like your formula and my table lookups arrive at about the same number ~26 PSI. Cool. :movember:
Dwayne Lane's Chrysler Jeep Dodge
