Tire Deflators
I ordered these based off what others had mentioned on here. Went out West earlier this month and aired down and up quite a bit. The verdict on these Skog's is that they were a complete waste of money. Very slow air out compared to just the deflators on their own (Res-Q). I removed them and the air came out faster.
They do attach as fast as you can push them on but they restricted air flow pretty bad. I will never use them again if anyone is interested, I can mail them.
I had the same experience.
I recently installed the Apex Rapid Deflators. I can air down from 30 to 15 on all 4 tires in about 2 minutes total, including walking around the jeep. Basically, about 15 seconds to bleed 15 psi. Last group trail run, I showed up late and everyone else had aired down. I was ready before the first jeep got 10 feet into the gatekeeper.
73TAWM
73TAWM
Troy
Missouri
21 JLU RUBICON 2.0T 3"LIFT 37's
Lumber Sales
Do you know if those work with the TPMS?
THAW
Foster
23 JL4DrRubicon
I'm not familiar with the Res-Q deflators so maybe there's a compatibility issue.
But, I'd guess the Chuck Mates weren't on your valve stems far enough to fully depress the valve core. Do you have OE valve stems?
Yes, I installed mine myself with the TPMS sensors in my 37s, in the driveway with a couple tire irons from Harbor Fright and a can of starting fluid to re-seat the beads. ...and a Modelo Negra🍺
73TAWM
73TAWM
Troy
Missouri
Lumber Sales
I do have OEM stems, or whatever they used when they changed out my wheels. They were seated properly as I tried everything. The air would come out quicker on one or two so I moved them around a bit to test. If I moved one that wasn't airing out properly to another tire it did the same thing. Once I took them off of the deflators the air came out more freely. Might work for yall but I will be doing something different.
73TAWM
73TAWM
Troy
Missouri
Lumber Sales
@roaniecowpony types faster than me which is not difficult
I guess it would help if I watched the video before asking. I love the idea of these but I know if I try to install them I'll bugger up my wheels with two crow bars. But I have no confidence in the boys at our local tire shop either.
Terrymo
Terry
2023 JLURXR 3.6 ET
You made me curious so I watched it. Figured I would save you some time. I don’t mind airing down at a normal speed. Looks like a cool product though.
73TAWM
73TAWM
Troy
Missouri
Lumber Sales
What is normal anyway? I was next to my dad who just bought a Thor's Lightning and he is done in seconds. If everyone was as slow as mine I assume I would feel normal ;)
