Thoughts on 3.6 longevity
  • Thread starter Deleted member 57375
  • Start date
  • Watchers 19
yokramer
Snark Incarnate
1Warped Jeeper
Tim
Frederick, MD
23 AEV JL370, 24 392, 23 Grand Cherokee SR, 23 CVO Road Glide, 23 Custom Harley
Retired or Unemployed
Maybe a Harley with 20” wheels.
Well, the cool kids have 23" or larger front wheels. (I think it looks stupid!) So, 20" is considered small. This is NOT mine!
Jeep Wrangler JL Thoughts on 3.6 longevity 1728095862080-vh
What do you care what I run. My money,my choice. What kind of harley do you ride?
Good point. Your call. As far as the bikes, the fast kind (for a Harley anyway :CWL: ) One has a 121" motor and the other has a 132". One Touring and one Softail.
Punknhed
Virginia
2023 Punkin Rubi XR
God that looks horrible.
Chris D
Phoenix, Arizona
2015 JKURHR Hydro Blue, 2019 JLUR Ocean Blue, 2025 JLURX in Mojito.
The 3.6l Pentastar seems like a pretty decent engine. my 2013 Badass T&C only has 145K on it, typical wear items, thermostat, radiator, water pump(because it was easily accesible), plugs, oh yeah, that POS oil cooler/filter housing (that was fun). Oil change interval is when it says change it. Do we drive it - yes, do we beat it - no. Same for the 2015 JKURHR and the 2019 JLUR, the driving that is.
1Warped Jeeper
Tim
Frederick, MD
Yes, it is hideous. I didn't get the way oversized front wheels. If you look under the rear fender and behind the saddle bags, most are running the factory wheel that doesn't match the front. The geometry totally changes, so anything larger than 21" should rake the front of the frame. I had a 21" wheel on a past Road Glide and that was as far as I thought it might look good.
SoK66
Jerry
Durango, CO
Jeep Gladiator Sport (3)
Watch some of the tear down videos on Youtube of the 3.6L and similar modern engines and you'll marvel at how mechanically complex they are, some of the cost compromises manufacturers make, and how common they fail simply because of poor maintenance. The current production 3.6L has no consistent fail points. The old JK era #2 valve seat issue was finally resolved some years ago and the rocker needle bearing issue was cured as of 2019. Change your oil regularly. Depending upon how much low speed vs highway miles, change at 3,000-5,000 miles. (If the mileage calculator on the dash suggests longer intervals, thank it for the suggestion and ignore.)
3.6L is a great all around engine and perfect for trail Jeeps, particularly matched to the 8 speed. You don't need 400HP to crawl an obstacle at 2MPH.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
You drive a Harley? That could explain the confusion over trying to put something other than 20" tires on a 20" wheel.
You called Nitto to confirm. That's fucking hilarious. Hopefully you realize you're infamous there now.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Punknhed
Virginia
2023 Punkin Rubi XR
i was seriously considering going to a 21 on my Ultra. it had a 16 inch 80 spoke wheel that was really pretty. but then i fucking ran the damn thing off the road a couple months ago...... im still sick over that fuckup.
