This easy drain plug looks much safer
_olllllllo_
William
The Wild Wild West in AZ
2019 Hellayella JLU Rubicon 6-speed
I run a short Fumoto valve under a skid plate. Haven't had a problem in 25 years.
I have been using the Fumoto for 6 years and I attach the hose to the nipple and don't get any spills. I run an engine skid so it is protected.
Valpo Jeep
Doug
Valparaiso IN
I think on my next oil change I am gonna try my fluid extractor then pull the plug and see how much still drips. This might become my future method if it works.
Already have the extractor from my Audi days as it was a top filter and needed a crush collar replaced every time. Worked very well with the daughters old Chevy Cruze as well. Both were top filter engines.
Ormond Beach, Florida
Retired at 55 ..
Regardless of whether you run with a stock oil drain plug or the forum favorite, a Fumoto Oil Drain Valve (Terrific) it is a very positive thing to add a magnet to the mix..
Consider buying a gun magnet with rubberized coating and attaching it to the bottom of the JL's oil pan. You remove the gun magnet just before you drain the oil pan and then after oil is drained re-attach the gun magnet.
Buy the gun magnet at Amazon. Here is one example..
Here:
Jeep Wrangler JL This easy drain plug looks much safer 1030228-6e6dabfb54aac25be4867e2c4593eb74
Note: For those that want to stick with an oil drain plug but want one that actually has a magnet on it... Well, The oil drain plug is a M14-1.5 . You can find a magnetic plug in that size most anywhere. Pick your brand... shop on eBAY, amazon, etc. It's the same size as the Wrangler JK uses..
SlickRicksWilly
2024 JLW (ordered)
This is how it looks installed. Works great and I have not had any issues. Would recommend.
Jeep Wrangler JL This easy drain plug looks much safer 41d1501e-c224-458d-b386-82c3e9d88ef4-1_all_221
Jeep Wrangler JL This easy drain plug looks much safer 41d1501e-c224-458d-b386-82c3e9d88ef4-1_all_222
Eyeball
1997 TJ & 2023 JLUR
I have the No-Spill drain on my JL and had them on my previous 3 trucks. All brass fittings and the hose makes for a no-mess oil change.
A little off-topic, but I tried one on my TJ years ago. I think it is a superior design to most including the ever popular Fumoto. It is almost as tight to the pan as a regular drain bolt but unlike most of these type systems it has the advantage of having two methods of preventing a leak.
The only reason I did not continue to run it was because I could not get a good angle of attack to start the threats with my skid plate preventing me from getting my hand where it needed to be.
GRXKen
Ken
Cedar Lake IN
2021 Rubicon, 2010 F150, 2016 Escape, 1970 GTX
Own and operate a remodeling company
I have done more oil changes in my life than I can count and I just don't see the point in these devices. When I crawl under they I am aways wiping things down and checking things out. I have a garage that's a shop and not a showroom and a couple spilled drips will never be noticed, maybe that's the difference.
Do they save a significant amount of time or mess?
travis304
Travis
2018 JL Sport S, Barely street-able S197/E85
Gonna be the boomer and say an aftermarket drain plug on any Wrangler is a solution looking for a nonexistent issue.
It's a single low-torque bolt. Anything else is adding unnecessary complexity.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
Time for sure. Hook the hose to the Fumoto and the other end directly into the 5 quart jug (assuming your engine holds 5 quarts or less). Let it drain, then put the lid on the jug and it's ready for recycling.
Also, if you have a skid plate in the way, the hose routes the oil down to the container rather than having it coat whatever is under the drain plug. My diesel uses 9 quarts but the skid plate catches the initial surge if I don't use the hose. I still have to transfer it to a couple of jugs but at least I'm not dealing with an oil covered skid plate.
