Tazer to JSCAN
Rustynail11
Mansfield, TX
2022 Wrangler JLU Rubicon
So some how some way I managed to misplace my Tazer mini. Search high and low and it is no where to be found. Not sure I want to the $$ for a replacement so going to go with JSCAN. The only changes I made with the Tazer was to enable LED lights.
Without resetting will plugging in a JSCAN and making changes with that cause any problems since previous changes were made wit a Tazer?
Grayhound
Michigan
Jlurd
It shouldn't, but if you find your tazer and plug it in, it will write what's married to the tazer over your jscan changes.
Pape
Quebec
JLU Sahara
worse case have a look at how to do the led light in jscan and once you connect it go have a look at it is configured for confirmation before pushing any change.
jav_eee
2021 JTR
I run the jscan and the tazer at the same time. I've changed settings with jscan while the taser is plugged in and the vehicle is on.
73TAWM
Troy
Missouri
21 JLU RUBICON 2.0T 3"LIFT 37's
Lumber Sales
This is likely a stupid question, but in the rare case that it's not...
Did you look under the dash to see if you left Tazer plugged in? :whew:
Rustynail11
Rustynail11
Mansfield, TX
LOL, not a stupid question. I doubted myself so I double and triple checked and even had someone else look
