Tazer JL feedback?
Stalkern
Nathan
Aurora, IL
2019 Rubicon 2-d
Does anyone have this installed?
Is it worth buying/installing?
Any problems?
TEAMSLO
North Las Vegas
23 392, gone 21 JTM & 22 JLURD
Have had them on both my previous and current jeep, no issues and yes, worth the $$$ if your upgrading/modding among many other features.
vetygud
Michael
Nisswa, MN
2022 Jeep Willys 2 door Sarge
Retired LEO
I installed mine last Saturday. Also put the wiring harness extension on. I have not had any problems so far. I made a hard copy of the Tazer JL Mini User's Guide to follow while changing the settings. Updated before it was installed. I have been going in and making changes since my initial install and have been getting the hang of it. No regrets and I would do again.
tecnic1
2021 JLR
I have the lite.
It might be causing some issues I've had with locker indication. Occasionally (frequently) when I put my jeep into 4hi or 4lo, I get indication that my lockers are locked, and that unlock is in progress.
Other than that, (which I'm not 100% sure it's a Tazer issue), it does everything I need it to.
Xorak
TN
2020 Hellayella Sport, 2023 Reign Sahara
Does anyone have this installed? Yes, currently using this product on 2 Jeeps (1 Tazer each)
Is it worth buying/installing? Yes
Any problems? No
CarbonSteel
You should compare the functionality of a Tazer to that of JSCAN and determine which meets your needs.
JSCAN is much cheaper than a Tazer, writes permanently to the BCM/PCM, and there is nothing that remains connected or married.
Worth a minute to compare the two before buying one or the other.
Terrymo
Terry
2023 JLURXR 3.6 ET
Any problems?
Not trying to be rude, but you will want to do a search on this forum. You will find hours of great reading from simple explanations to in depth technical info.
Bill Hesson
Bill
Alpine Ca
2024 Rubicon X, 2022 Ram 2500 HD, 2017 JGC
I have a 2024 Rubicon X on order and would be interested to here when someone has the opportunity to test it on 2024.
LostinBigBear
Sunshine
Big Bear Lake, CA
2023 Wrangler JL
I have one too and no regrets. It’s definitely an education figuring it out for me personally. I like gadgets, but this thing is ?! I used it to program my jeep for the passive entry, LED headlights, 8.4 stereo, ORP, turned off seat belt chime and ESS, turned on turn signal camera and the one I can’t seam to figure out is how to get the navigation to let me use it while in motion. No matter how many times I mess with it, that one never turns on. I originally bought the Tazer for the passive entry, and look how many other features I ended up with?!?
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
Yes
Yes
Yes, had my tazer installed for 2 years now. No changes, no updates. A couple of weeks ago the rear camera no longer works when the turn signal is on. Does anyone have any clues what I should do?
Stalkern
Nathan
Aurora, IL
2019 Rubicon 2-d
...... No worries... .... just not looking to spend hours reading through a forum hoping to come across what I'm looking for...
kah.mun.rah
Merenkahre Jr.
Duat
Any problems? No
same ⬆
I got it for the tire size recalibration.
It was nice for disabling the auto start/stop back when I had a non-eTorque version of the JL.
Limiting or turning off the PSI warning threshold is nice when airing down on the trail.
Other features like the light show are fun.
elf883
steven
NY
2024 jlu willys anvil
stationary engineer
in motion will not work if you have turncam ON turn it off and you will see in motion works
