jeremyjeep
In the fifth picture, you showed the cable going through the upper right grommet (existing). But then in all of the pictures later, you drilled a hole for it. Was there a reason not to use the existing hole where the existing grommet is located?Pulled the trigger on this project today. Very happy how things turned out. Here’s my write up.
I used the parts I had mentioned above. Used a paracord bracelet for the release. Bought a six inch cable (King Marine Bimini Top 6" Nylon Clear Coated SS Cable with loop - 2 pack https://www.amazon.com/dp/B071DVJBKZ/ref=cm_sw_r_cp_api_i_Zd77AbGKV30CM) and shackles (Cosmos ® 10 PCS ½ inch Silver Color Stainless Steel D Shackles with Cosmos Fastening Strap https://www.amazon.com/dp/B008KYDZE6/ref=cm_sw_r_cp_api_i_ne77AbGD08EPR) along with this handle (Bartact TAOGHRPBR - Jeep Wrangler JK Rear Side Sound Bar Paracord Grab Handles (PAIR) - Made in USA - BLACK/RED https://www.amazon.com/dp/B00PO17GDO/ref=cm_sw_r_cp_api_i_6e77AbN1ZSCMS).
I popped off the rear trim using a trim tool. Popped off easily. I used a shackle to attach the cable to the mechanism pictured. I initially tried the plug port in the pics but didn’t have the downward angle I needed to release. So I drilled a hole in the plastic and put a rubber grommet in the plastic.
For the handle I used the two unused threaded holes. The top hole is an M8 and the bottom is an M6. Both are fine (28) thread. I had an M8 but didn’t have an M6 that was long enough. I bought a 35mm and it worked but would have preferred a 40 or 45 for mor depth in the threads.
I drilled through the plastic and screwed them through after replacing the trim. Painted the washer and bolts but the paint came off when torquing down. Will paint in place. I hope some of you can make used of this. Used the extra handle and a shackle as a handle for my Hydroflask. See pics below.
