Tailgate reinforcement needed?
NINTH
Jay
Socal
2 door JL Sport
Getting conflicting reports that the stock JL tailgate hinges can either support a total of 85lbs OR an additional 85lbs + the stock spare?
Can someone clarify for me?
Have a JL Sport and just upgraded wheels/tires to Method 703 17x8.5 with Falken Wildpeak AT3 285/70/17 so the new weight of the wheel and tire combined is about 95lbs.
Do I need to reinforce the tailgate or can the stock hinges support this increase in weight?
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
No. That combo weighs no more than a stock Rubicon/Willys wheel and tire.
NINTH
NINTH
Jay
Socal
2 door JL Sport
I thought the stock wheel/tire set up is like 70 lbs? I guess a 20 lb jump isn't crazy tho
The Last Cowboy
San Antonio, TX
A 33' Rubicon/WIllys tire and wheel is ~80 lbs, and has no reinforcement. An XR 35" wheel and tire is heavier yet (~86 lbs), and will come with the Mopar reinforcement., which stiffens the tailgate, but does nothing for the hinges.
My Toyo RT Trail tire, with a factory wheel weighs ~80lbs. I have it mounted on the tailgate with no modifications, for nearly a year now, and have had no issues.
According to specs, your combo will weigh 85 lbs, unless you choose poorly, and get load range E.
kah.mun.rah
Merenkahre Jr.
Duat
I ran a 35" tire mounted to a heavy wheel with two gas/water cans attached to the spare tire down a lot of bumpy off-road trails with no issues with the stock gate or hinge. Jeep will never say that beyond what they provided as stock is "ok" and the internet (especially tailgate support vendors) will use scare tactics to make you worry about it. One other thing to note is that the JL design is a lot better than the JK design and JK owners have been running heavy tire/wheel setups on their stock gates and hinges for 18 years.
Jeep Wrangler JL Tailgate reinforcement needed? 1757959832277-o
The Last Cowboy
San Antonio, TX
Oh, I forgot to add that I also have a Metalcloak spare tire lift bracket that weighs about another 10 lbs. And, I eliminated the third brake light rack, that saved about 1.5 lbs.
LSJKU
Hill Country
2025 JL Rubicon, 2019 Raptor SCAB
doodlebug
Currently, I run LT315/70R17 (E) BFG KM3 + 27x8.5 703s that weigh in around 93 lbs. I will be going to an LT37x12.5x17 (E) + 703s that weigh about 104 lbs after completing the required drivetrain mod's.
I installed the tailgate reinforcement, but not out of an abundance of concern hanging 35"/703s off the tailgate. Never had any issues with my 2018 tailgate and 35's. I did it for a little peace-of-mind when I put the 37" combo back there, however false that "peace-of-mind" may turn out to be.
Nice wheels by the way. I'm lovin' the beadgrips.
Jeep Wrangler JL Tailgate reinforcement needed? IMG_4299
The Last Cowboy
San Antonio, TX
Another thing to keep in mind is that one of the more common reinforcements available out there will only add extra weight to the stock tailgate hinges. Very few on the market have any type of modification to the hinges themselves.
LSJKU
Hill Country
doodlebug
That's a great point. And I may go to a bumper-mounted setup anyway, when I get to that stage of mods.
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
The stock tailgate can't support sh*t, reinforce it.
rickinAZ
Phoenix
2026 MOAB 392
I've followed Jeep forums for almost 20 years and this is, by far, the most commonly asked question. I always play it safe and reinforce.
But...you'll always get some forum member who claims he carried a Sherman tank on his stock setup for "years" without damage. :)
p.s. I suspect 95lbs will not cause an issue. That said, my current rig has a 103lb spare running on the optional factory reinforcement carrier. Also be careful of calculating weights from the vendor's specs. My spare should have been 5lbs lighter than it's actual weight.
rickinAZ
Phoenix
2026 MOAB 392
And... Artificial intelligence tells us not to ignore the 2.5lbs of air in my tire. That accounts for half of my discrepancy. :). And...before you say I've got too much time on my hands, through the wonder of technology, this took less than a minute.
I asked: "How much does the air weigh in a 35 12.5 17 tire inflated to 30lbs?"
Determining the precise weight of the air in a tire requires knowing the volume of the air cavity and the pressure and temperature of the air. Since a tire is not a perfect cylinder and its shape changes with pressure, an exact calculation is complex. However, we can use the ideal gas law to make a reasonable approximation.
Approximate Calculation
First, we need to estimate the volume of the tire. The dimensions "35 12.5 17" refer to:
  • 35 inches: Overall diameter of the tire.
  • 12.5 inches: Section width of the tire.
  • 17 inches: Rim diameter.
To calculate the volume, we can model the tire as a torus (a donut shape) or a hollow cylinder. A simpler, but less accurate, method is to treat the tire's air chamber as a cylinder and subtract the volume of the wheel. The volume of the air inside the tire can be estimated to be approximately 3.47 cubic feet at atmospheric pressure (0 psi) and about 10.55 cubic feet at 30 psi.
Next, we use the density of air. The density of air is not constant; it increases with pressure. At standard temperature and pressure (STP), the density of air is about 0.0765 pounds per cubic foot. The gauge pressure of 30 psi is the pressure above atmospheric pressure (about 14.7 psi). Therefore, the absolute pressure inside the tire is 30+14.7=44.7 psi.
Since density is proportional to pressure, we can estimate the density of the pressurized air as:
Densityinflated≈DensitySTP×Atmospheric PressureAbsolute Pressure
Densityinflated≈0.0765lbs/ft3×14.7psi44.7psi≈0.233lbs/ft3
Finally, multiply the volume of the air at 30 psi by the calculated density to find the weight.
Weight=Volume×Density≈10.55ft3×0.233lbs/ft3≈2.46 pounds
The weight of the air in the tire is therefore approximately 2.5 pounds.
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
I've heard people complain about the Mopar reinforcement? Any validity to that?
