Tailgate rattles really bad
Huntertodd80
Hunter
Charlotte
2018 Jeep Wrangler JL Unlimited Sport
Hi everyone I hope I am posting this in the right spot. I had a shop install my spare tire carrier from smittybilt and ever since they can’t get this rattle to stop. I have messed with the latch and everything back there and I can get it decent for about a day but then by the next day it seems to come back and I have to sit out here for an hour adjusting everything again. Just want to see everyone’s thoughts on how to fix this and what could be wrong/ needs adjusting.
kah.mun.rah
Merenkahre Jr.
Duat
First thing is to mount the tire closer to the gate (if adjustable), and to make sure you have bump stops that bridge the gap between the tire and the gate.
Huntertodd80
Hunter
Charlotte
It’s as close as it can be and I do have the bump stops as well. It seems to rattle at the top of the tailgate, you can kinda see it in the video. I’m tempted to get a different carrier I’ll just be out of the $600 spent for the smittybult one
kah.mun.rah
Merenkahre Jr.
Duat
From the video I don't see the bump stop on the driver's side and it looks like the tire/wheel is shaking more than it should.
Huntertodd80
Hunter
Charlotte
Yes! Sorry! I had the bump stops and took them out and it still occurred no matter what! I should’ve been more clear!
kah.mun.rah
Merenkahre Jr.
Duat
This hole is where the bump stop should be:
Jeep Wrangler JL Tailgate rattles really bad 1713551820838-37
kah.mun.rah
Merenkahre Jr.
Duat
Huntertodd80
Hunter
Charlotte
I will try that next! I still have them at home from when I took them off. Care if I post another video once those are in if the rattle persists?
kah.mun.rah
Merenkahre Jr.
Duat
Also, can you say which Smittybilt tire carrier you had installed? Maybe a picture of the side of it with the tire off of it? I think that most of them are adjustable and the closer you can mount the tire to the gate, the less wobble you will get. The bump stops do their best to reduce it but mounted as close to the gate as possible is key.
jludave
The Isle of Long
IT Manager
What's with this gap here? Unless that is an optical illusion, something isn't right with your tailgate. Also, in the video, it sounds to me like the rear glass above the spot I circled is rattling, not the tailgate.
Jeep Wrangler JL Tailgate rattles really bad 1713552937589-ey
Obviousbicycleco
Zach
Minnesota
2018 Jeep Sahara JL
My tailgate rattles the same despite the gap being even the whole length. I just figured it was a Jeep thing. I did ordered a part from Amazon that will hopefully help.
https://a.co/d/0hER5b7P
Terpsmandan
Penn Yan
That started happeing to my tailgate after I installed the TeraFlex tire carrier for my 37. Ended up adding the Teraflex tailgate hinge. Should have done both at the same time. Very solid.
Pig-Pen
Banned Camp
2018 JLU
jabroni
I have the rugged ridge spartacus hinged carrier. It does not use the bumpstops but the tailgate is super solid. No rattles (like before i installed it). About $600 for the whole kit iirc.
ive also previously installed the teraflex kit. Im happy with the RR kit and the savings.
CorgiAttack
2022Rubicon
Try moving the latch and limit block a little further inward and try it.It looks like the rear door version doesn't fit tightly and has a large gap
