Tail pipe submerge question
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Yes, those valves are designed to close when submerged but taking on water through the valve is a misunderstanding of how that system works. When that valve is closed water can still come into the axle. That valve is designed to breathe, i.e. as the axle heats up during normal operation it needs to vent. Yes the vent is also designed that if submerged it will be pushed shut from the pressure of the water on it so as water can not go down that tube. That's where most people stop and say I'm good as long as I don't submerge that vent and that is where they are wrong.
The danger is when the axle is hot (at operating temp from being driven), and as noted, it is venting. When the axle is suddenly plunged into water or mud and allowed to stay submerged it will cool rapidly. When it cools like that it forms a vacuum and pulls that valve shut and that is when the problem occurs. Now you have a vacuum and since it can't suck in air through that vent it's going to start pulling in through the seals and what's on the other side of the seals? Water. That is the real danger of submerging an axle that is at operating temp.
The solution to this is to run ALL (both diffs, tranny, t-case) to a common point up in the engine compartment as high as possible but DON'T put a closable vent on it. You typically tie them to a manifold that has a filter on it, ARB makes one for around $75. This way you keep out debris and it can breathe in/out without causing a vacuum. And if you are worried about sucking water in through them when they are way up in the engine compartment you've got bigger problems, like a hydro locked engine, to deal with :)
A friend of mine had the exact opposite thing happen to him. His breather valve was caked SHUT with mud. As his axle heated up it still needed to vent so it vented itself right out the pinion seal and he was leaking gear oil there. Time for a new pinion seal
Thanks, good info, going into the pond slowly usually does the trick for me. I tend to the let the axle cool down a bit in shallower water before submerging them completely. Never had an issue.
Arterius2
Jerry
Vancouver, BC
Side note: I just changed my diff fluid yesterday and the front had a tiny bit of milky color to it. My wife is very fond of fording water while we are off roading and it looks like we sucked a little water in there.
Isn't the front breather up to the engine bay?
mgroeger
Southern UT
2021 JLUR 2.0T
Pretty sure it is and this is a great example of how water can get sucked in through the seals since I'm pretty sure it wasn't taken in through the valve.
wolfdog
George
Southern Massachusetts
2006 Yamaha FJR1300, 2021 JTO, 2018 JLU Sahara
Maritime Artisan, Mayflower II
If you're jet skiing/launching in salt water and your in that deep you're nuts anyway! Use someone else's vehicle!
Go jeep!!!
jameslavis
toronto, ontario
Jeep JL Unlimited Sport S
Only fresh water here. I wouldn’t even use my ski in salt water. Either way, no salt water in Toronto.
It’s not a big off road vehicle. I’ve always loved them and I launch the ski in some real terrible launches. So need the off-road there. Just a basic question on the pipe going under and slopes backwards. Can’t help it sometimes.
mgroeger
Southern UT
2021 JLUR 2.0T
Just don't do this...
Jeep Wrangler JL Tail pipe submerge question t3l2yobjcvo01
DaltonGang
Doesn't Play Well With Others
Blah blah blah. Too many talking heads around here. The best advise that was given, was not to get water into the air filter, period. I've driven through flood water, for extended times, at around 42 inches. Hair raising, but no damage to anything, except the license plate. The water bent the front plate. Also no water in the axles. They were drained and checked, by me. The reason no water got into the axles was that the axles were cool when I entered the water. me
So, just launch the jet skis, and dont worry about it.
Hava-Jeep
Lake Havasu City, AZ
2019 JLU Rubicon,
You’ll be fine.
wanderer
Ralph
Carlsbad CA
Engineering Geologist
So if you have a Mopar snorkel does that increase your fording depth?
VXSKAXV
JL Sport S
If you have a stock rubicon and add a 5 inch suspension lift and kept the same tires you only gained 3 inches of lift. But like the other guy stated, you did not raise your 30 inch water fording capability. It stayed the same. Like he said and he is correct “ that’s not how things work”.
mgroeger
Southern UT
2021 JLUR 2.0T
If you have a snorkel you look like a tool but to answer your question technically yes since it will keep water out of the intake. However have fun with cooking all of your electronics if you go deep enough for long enough and enough water gets in to submerge them. If that water is coming over your hood I guarantee you it's coming in the cab.
We were deep enough that the water was at the bottom of the headlights and some water came up through the bottom of the Jeep through any bolt it could find. I was pretty shocked at how quickly it happened. Fast forward one year and I needed to change the tire out on a trail and there was still a puddle of water in the little tub that holds the jack. Wow did that stink.
wanderer
Ralph
Carlsbad CA
A tool? Geez ! I actually like it a lot and am anything but a tool. But I don’t need or care to hear you opinions. Very been out west on long trail ride. In the dry DUSTY desert? High clean air.
