Is 23mpg a pipe dream?
4Play1
Shannon
Arkansas
2022 JL Willys Two Door Sarge Green
Brand new 2024 Willys 4 door 3.6 auto soft top here. Theoretically, my vehicle is rated at 23mpg highway. I only have 400 miles on it so I realize it's a brand new engine and mileage should increase a little once it's good and broken in, but I'm guessing this thing will never see 23mpg on the highway. Not with these heavy 33" tires and a 4.10 rear end. Maybe a 2 door sport with street tires, but not this Willys. Are there any 2024 Willys 4 door, 3.6, autos getting 23mpg on the highway? My work commute is all highway, 23 miles each way. I tried to hypermile it the other day. Didn't go over 60mph. Averaged 18.7mpg.
My 22 Willys 2 door with the 2.0 can but I don’t think a 4 door air the 3.6 can get there. Shoot for 20 mpg at best.
Ramcharger
Stephen
Worthington Minn
2022 Ram
2024 2 door rubicon X 3.6 manual
7551 miles--- accurate mileage 16.8 not from that mick mouse gauge cluster
never over 75 mph
dstevens
CA
2024 JLURX
2024 Rubicon X 13,000 mile average 15.6 mpg @ speeds up to 75 mph.
Powdermike
Phoenix, AZ
2019 Unlimited Sport
Stock 2019 Sport 3.6L auto….always use 91 octane and 5w-30
Monthly roadtrip to UT, mostly country roads……maybe the catch can helps a bit🤪
Jeep Wrangler JL Is 23mpg a pipe dream? IMG_8820
smokeythecat
2021 Willys Sport 2-door, 2019 Mini Cooper S
there is a reason there is a song titled I can't drive 55. It works. You'll die from being rear ended, but it works
I was probably the only one in the nation to be sad when they started lifting the 55 mph speed limit. I was getting really good gas mileage at that speed.
Fatbob Frank
Frank
N.E. Iowa
2024 Wrangler Willys
Lab Tech
They lifted the 55mph limit?
Not in Iowa apparently.
I have to drive an hour and a half to see a 65mph sign...
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
2021 Willy 2.0 from my brother
He only drives Hwy from East Coast
and my 3.6…. Fml
Jeep Wrangler JL Is 23mpg a pipe dream? IMG_5828
Jeep Wrangler JL Is 23mpg a pipe dream? IMG_5829
Hercules
Clearwater, FL
2012 Ram 2500 Longhorn, 2022 JLURD
Is 23 mpg a pipedream? Not with a diesel it’s not. Is get 24mpg fully modded.
rock123
Bobby
Alaska
TJ
I don't know why people keep bring up the diesel on here- it wasn't about that engine.
The cost savings are erased with the increased maintenance/fuel/DEF cost in the first place. And then you have the double whammy with the price of any future repairs- a EcoD turbo alone will cost you more than the entire cost of a brand new 3.6 crate engine. The EcoD crate engine will cost you $30k+ at the dealer, so the savings is just not there at all anymore.
dstevens
CA
2024 JLURX
Dear diesel owners, please only give fuel consumption figures by mass not volume. You've got a fuel that's 13% more dense.
Oso Fell
Hell
I really don't understand people's obsession with gas mileage. What I understand even less is why folks who are inclined to obsess over gas mileage would buy a Wrangler. It's the equivalent of a calorie-counter adopting a McDonald's-only diet.
šŸŽÆ
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
It is what it is with us. That’s why it doesn’t bother me if the mpg display is accurate or not. Using the same method, it will work for measuring improvement.
Our JLU Rubicon is a nicely equipped, hardtop, tow package. Completely stock with KO2 tires, driving conservatively I could manage a displayed 20-21 mpg.
It’s still stock at 101k miles. I’ve swapped in NGK plugs, did the unrelated oil cooler swap, and added lower rolling resistance pizza cutter size hybrid pattern AT tires, Kenda Klever RT tires that are 35x10.5R17. . I’m using the Tazer Mini to calibrate the speedometer. I changed differential fluid too. Stock 4.10 gears. I now have gained a SOLID 1 mpg gain.
I assume it being a Willys, it might have mud tires? AT tires will generally have less rolling resistance. Narrow will be even better.
