Tail Gate Reinforcement
LARSONEM
Eric
Eaton Rapids, MI
2022 Jeep Wrangler Rubicon XR Unlimited, 2021 Jeep Willys 2 door
I had the Teraflex heavy duty reinforced carrier on my 2012 with a 315/70-17. It was really stout. My 2022 with the XR package and 315/70-17 tires came with the Mopar reinforced carrier. I don't think it's as stout as the Teraflex carrier, but Jeep says it will handle the 315/70-17 tire size that came on the vehicle, so that's good enough for me. I don't do a lot of crazy off-roading anyway that bounces or jerks the Jeep, so I'm sure it will be fine.
SadRobot
Los Angeles
2025 Prius LE
I was on the stock Sport carrier when I had 35s. I got the Teraflex once I moved up to 37s. My tires + wheels come in at about 100lbs now.
I never had issues with the 35s, but the tailgate was started to sound a little bit creaky every time I opened and closed it.
BDinTX
Dallas, Tx
I have the Taraflex mount and gait reinforcement and love it.
Isn’t the tire supposed to be snugged up tight to the tailgate reinforcement?
2nd 392
Ca
It supposedly does, if not I would like to know. 8.5” 1mm wheels ordered to replace the stock ones and planned on the Teraflex to snug it back.
rohdawg
Long Island, New York
Merchant Marine
It does. It’s very adjustable and you can get your tire right up against the tailgate. There’s not enough room between the tire and the tailgate for me to get a finger between the two. You shouldn’t have a problem.
I don’t have a better picture at the moment.
Jeep Wrangler JL Tail Gate Reinforcement IMG_8720
BDinTX
Dallas, Tx
I guess I should have worded it differently. The wheel should be snug against it the Teraflex tailgate reinforcement.
My wheels are 0mm offset / 4.75” backspace and the tire is pressed tight against it and there is about 3/4” more adjustment available to go closer (if the tire wasn’t hitting already).
2nd 392
Ca
@rohdawg @BDinTX — gentlemen, did you use the Teraflex 3’rd brake light mount ? If not did you find something to plug/cover the wire hole ? I would prefer to just use my light ring. Thanks ?
rohdawg
Merchant Marine
I am using their third brake light.
The light is a separate attachment. No hole to plug.
Here’s a better picture of how close I was able to get the tire, along with one of the third brake light attachment so you can visualize what I mean.
Jeep Wrangler JL Tail Gate Reinforcement IMG_8724
Jeep Wrangler JL Tail Gate Reinforcement IMG_8723
BDinTX
Dallas, Tx
Yeah I did use the factory 3rd brake light relocated to the middle.
pics because why not
Jeep Wrangler JL Tail Gate Reinforcement IMG_2124
Jeep Wrangler JL Tail Gate Reinforcement IMG_2125
cafecito820
Lucas
Winston-Salem, NC
2021 JLR, 2023 Charger 392
The Mopar relocation kit covers it up perfectly. We're running a wheel ring LED as well.
kah.mun.rah
Merenkahre Jr.
Duat
Question is
"Is the Tire Carrier also designed to carry the 35" tire"
Yes (especially BFG considering their size and weight). The brake light on the stock carrier is also adjustable for 35" tires.
2nd 392
Ca
From watching the install video there is an oval wire hole on the camera stalk for the light connection, that crap and water would get in if the light isn’t used ?
BDinTX
Dallas, Tx
I wouldn't say the light does an effective job of covering up that hole. Water can still get in, mostly when washing, but I didn't notice too much other junk in there. Probably because it's at the back of the vehicle inside a wheel.
2nd 392
Ca
The pest is back, size is hard to judge from a pic but if I got an extra center cap and managed to drill out the center without ruining it. You think it would stick out enough to cover ?
Jeep Wrangler JL Tail Gate Reinforcement FE87A431-C8D7-46AB-A01F-801A43EA9907
