Synergy wheel spacers
Five1
York, PA
2019 Rubicon Unlimited
For anyone interested in running wheel spacers in their stock Rubi wheels/tires... here’s what it looks like.
Before and After.
SYNERGY MANUFACTURING HUB CENTRIC WHEEL SPACER KIT 5X5,1 5/8IN
KingCon
Boston
2018 Rubicon jl
Before and After.
All you need now is a half decent offset wheel(+12 and under)
Looks great...hard to imagine 1.5" makes that much of a difference, but it does
HealthRebel
Jerry
Colleyville, TX
2020 JLRU Ocean Blue
Before and After.
Looks great. So... I am really interested in how it effects your drive. Different? Better? Worse? In the rain and mud, does it throw more debris on the side of your JL? Did you check to see if there could be any warranty issues. Great color with the GCM by the way.
HealthRebel
Jerry
Colleyville, TX
Could you post some pics from the rear, before and after?
Five1
York, PA
I didn’t notice any difference in the ride quality. Right after installing them, I took a 200 mile trip on the highway and everything was fine. I didn’t have it in the mud yet, but I’m quite sure it’s going to fling mud up the sides. No idea about warranty.
blessidsoul12
Jordan
Walla Walla, WA
2018 billet silver JLUR, 2019 chevy suburban
They look great. Very subtle, but just that little bit of offset from the spacers gives it a totally different stance. There are multiple threads over the past few months specifically regarding spacers- pros and cons. I think the consensus is that they shouldn't have any more of an effect on your warranty than adding aftermarket rims. Spacers are easily removable, but will need some extra torque to get them off after using the thread lock. I absolutely LOVE LOVE my spacers. I thought my ride quality improved in respect to steering after I put them on. I thought I had perfect steering prior to the spacers, but once they were on I realized I didn't have perfect steering before. My MPG has not changed and offroad I can't say I had any issues I would implicate the spacers for (or any issues at all for that matter.)
klawrence3
Kyle
Conover
2018 Sahara JLU
Any chance of getting some photos from a distance? Curious how it looks with the factory tires that aren’t as wide as some others. Thanks
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
I am pretty sure we have the same Jeep and I have a pair of the 1-3/4 sitting on the shelf in the garage.
ptoemmes
Pete
JLU Willys “Edition” TBD Mar 2021
Curious..post #2 references 1 1/2" spacers. Synergy WEBsite - for the JL - indicates that the 1 5/8" spacer is replaced by the 1 3/4" spacer. They do have 1 1/4" and 1 1/2" spacers for other Jeep models.
So...the studs are a tad longer on the JL as I recall thus maybe the 1 3/4" is to eliminate any need to grind them on aftermarket wheels. But stock wheels have the recesses to handle an exposed stud end, but how long?.
Offhand: https://www.synergymfg.com/synergy-hub-centric-wheel-spacers.html?category_id=5983
1) Can any of the other listed spacers work on a JL?
2) Would a JL spacer (from someone else) at 1 1/2", 1 1/4" or even 1" clear for a stock wheel no stud grinding?
quietpeen
Chambersburg, PA
2019 JLUR
I have Bora 1.5" spacers and stock wheels. No issues with the studs
ptoemmes
Pete
Thanks. I just sent an email to them asking about 1.25" and 1.0" spacers and stud grinding.
Pete
Rubicon_LA
Los Angeles
2018 JLU Rubicon
I have Synergy 1.75" spacers. Give a great look, and a very slight change to better steering, especially on turns.
I think anything less than 1.75" will be hard to install on Rubicons or I might be wrong.
AllJumpStyle
CA
JL
1-5/8" spacers cleared most JL studs without trimming, but we had one vehicle in the shop that required the rear studs to be slightly trimmed. I believe it was a Sport. 1-3/4" spacers don't require any trimming.
If you want different backspacing/offset than the JL spacers we offer, you will want to look into aftermarket wheels.
