Sway link help
NyRey87
NyRey87
Nyles
Reno, NV
2021 JLURD
I’m not sure if the stock nuts are deformed to hold, or the wrong thread, but if you reused them, if may be worth getting a new set of nuts.
When I put the mopar links on, I could not get them to fully seat and I broke out an impact to drive the hex. A set of the correct flange nuts from lowes spun right on.
Using what came in the kit from Clayton. Possibly the shop cross threaded them and I was actually never getting it any tighter and was just stripping out the allen slot on the inside of the nut.
NyRey87
NyRey87
Nyles
Reno, NV
2021 JLURD
I had to use a pass through wrench with the Allen wrench inside of it
Jeep Wrangler JL Sway link help B996C0D4-9788-4742-8F45-D14779E588C4
smokeythecat
2021 Willys Sport 2-door, 2019 Mini Cooper S
It just keeps spinning if I don't try to use the 6mm.
Looking at new sway links, not really sure I like the design on these.
Looking at the Eibach ones I like that they have a washer that looks like it has an insert that fits into the sway bar to prevent slop, even if it was loose
https://www.extremeterrain.com/eiba...s-for-2-to-4-inch-lift-ak41-51-023-01-20.html
https://www.extremeterrain.com/eiba...s-for-2-to-4-inch-lift-ak41-51-023-01-02.html
I want something that isn't a nightmare to work on, especially since I am such a noob to this stuff
Since you installed a lift kit presumably you are going off road. Why not replace those links with quick disconnects? Or do you have a Rubicon?
NyRey87
NyRey87
Nyles
Reno, NV
2021 JLURD
No Rubicon.. The kit I had installed was the Clayton 2.5 Overland kit. It rides amazing I just noticed the sway link sucks. I am open to getting new ones even tho these are essentially new. I would like something that isnt maddening if I have to try to tighten it. I am open to QD ones as well.
NyRey87
NyRey87
Nyles
Reno, NV
2021 JLURD
Okay looking at either the Quick disconnect links from Metalcloak or Rock Krawler, I have read a lot of good stuff on the MC one but I couldn't find much on the RK one. Anyone recommend one over the other? My only concern is the MC one being a little too long. I have a 2.5" lift but I got about 3.5" on the front and the current length of my sway link is 11-11.25" or so and the MC one is 12.25" minimum I believe. Currently the sway bar has a slight upward angle to it, I would say 5-10 degrees
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I wonder if it’s not some kind of deformed thread lock nut. Look at the notches by the threads on the nut.
jgo138
Justin
San Antonio, TX
2019 Sahara
Education
I had this annoying knocking sound a few days after installing the 1.5” Clayton lift and found out it was the rear passenger sway bar endlink not being fully tightened. I used an Allen wrench the first time and thought I had it tight as hell, but I was at my friend’s garage and didn’t have anything else. Today I tightened all 4 bolts with an 18mm wrench and a socket wrench with this bad boy:
Jeep Wrangler JL Sway link help 1649040850963
This made the process 10x easier, so it’s definitely worth the few $$ it costs. For the front sway bar I kept the JKS quick disconnects and they are solid!
NyRey87
NyRey87
Nyles
Reno, NV
2021 JLURD
I'll definitely pick one up next time I'm at the Auto parts store.
I noticed the one I was trying to tighten was a little stripped out so I just clamped the other side of it and used a socket on the nut and I was able to get it tight, I don't think I can do it any other was as I'm fairly certain the inside part is to stripped to tighten =/
I am looking at still getting QD ones for the front, Looking at either RK Gen 2 or MK or even maybe the AutoLynx one even tho its crazy expensive.
