Strange Issue With Headlight 'Auto' Setting
YGBSM392
Oklahoma City
2025 Rubicon 392, 2024 2-Door Rubicon X, 2024 Mojave X
I fly da plane...
My headlights always switch off when I’m driving my my exes place. Odd, ain’t it?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
If you are parking under a streetlight bright enough to trigger the light sensor, you may want to try a little further down the road.
Cartman
ANDREW
Slovakia
Jeep JL Sport+ 2d 2023
in the middle there are front and rear fog lights. there can be only front fog light.
circle is off. everybody have to have off /circle/.
Jeep Wrangler JL Strange Issue With Headlight 'Auto' Setting 1748361128047-k8
Heimkehr
Pennsylvania
2021 JLU 2.0T
Does anyone RTFM? 🙃
The switch in my JLU. Full manual control because I can breathe and blink at the same time.
Jeep Wrangler JL Strange Issue With Headlight 'Auto' Setting 1000014900
3arl0fBruce
Rob
Northern VA
'23 Wrangler JLUR MT - Earl
Does anyone RTFM? 🙃
By the way, the center of the dial is the button to turn the fogs on and off, in case that wasn't clear from earlier posts.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Man, there's a lot of combinations of light switches out there.
Fogs or not, one button within the wheel or two (maybe zero?), auto or not, off or not, two vertical dials or one (with a gaping blank spot!).
X35
PA
2025 Wrangler Willys XR
Having full control of shit is ideal, however, every vehicle I’ve ever had with auto headlights they've worked pretty damn good. Just set it on auto and forget about it unless you need them either on or off in certain weather conditions or you’re trying to hide from the old lady or the five o 🤷🏻‍♂️
Badunit
VA
1997 TJ, 2023 JT
No response back from the OP so far. I assume he's got it figured out by now.
Wbino
NJ
I'm assuming the order of protection is still in effect?
YGBSM392
Oklahoma City
I fly da plane...
Scopedog
Scopedog
San Diego
2023 Jeep Wrangler Unlimited High Tide
It appears you have your high beams on. Try pulling the turn signal lever towards you. By default, you can't have your fogs on with high beams (modifiable with a Tazer/JScan though).
Thanks, this was the solution. I don't think the lever was in the highbeam position but fidgeting with the lever made the auto headlight setting start working normally. I also turned off the foglights.
