Strange Brakes Issue
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Brakes feel fine, work fine, pads good, no sign of leaks found, no loss of brake fluid. However if I come to a full stop, hold it for a moment, then mash the brake pedal down extra hard both BRAKE and ABS lights flash and the JL throws the following codes:
U0418 - Implausible Data Received From Brake System Control Module 1
P1C4E - ABS DTC Present
C0042-62 - Brake Pedal Position Sensor - Signal Compare Failure - Stored
C2227-00 - ABS Disabled ECU - Stored
U0415-00 - Implausible Data Recieved From ABS - Stored
The BRAKE and ABS dash lights disappear quickly once I get moving again. I can reproduce this fairly consistently and also completely avoid it by not pressing extra hard on the brake pedal after stopping. I do have ACC if that matters.
Any ideas of what is going on?
jludave
The Isle of Long
IT Manager
Reinen
Reinen
Utah
