Stock 4xe Willys rubbing?
SOON
Roseville CA.
JL Willys 4XE
So the other day I was making a couple U-turns and I rubbed. Is that normal? One of the turns I came up on the sidewalk but the other I didn’t. I’d have thought that fully stock that wouldn’t be a thing but I guess not.
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
Fully stock? Nope you should NOT be rubbing. Oversized tires? Yup very real possibility.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
It has the Firestone mud terrains that come stock. Not oversized
Where is it rubbing? The fender, the fender liner, the LCAs?
SOON
SOON
Roseville CA.
JL Willys 4XE
I’m not sure? I’m assuming it’s the liner but don’t know. What’s the LCA?
It’s not flexing so I can’t imagine it’d be the actual fender
yokramer
Snark Incarnate
Yea youre gonna have to get under there and see if anything is close. LCA is lower control arm.
Wabujitsu
Sarasota, FL
Retired US Army
Check your fender well liners to see if one is sagging a little off of the inside area next to the tire. It’s a problem that has been reported by some folks. It happened in my wife‘s Sahara when I was giving a ride to a rather “large” couple, both sitting on the passenger side of the vehicle. The rear passenger wheel, because of the tilt of the Jeep, was occasionally rubbing the inner fender well liner.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
As long as there is some mud residue, you can normally see the rub sections as clean smudges.
LCA = Lower Control Arm
May want to look at the bumper closure pieces.
Eric_Nail
Eric
Tumwater, WA
2023 Willys 4xe
s giving a ride to a rather “large” couple, both sitting on the passenger side of the vehicle. The rear passenger wheel, because of the c
This is the issue with mine! It took all of 2 seconds to realize it when i cranked the wheel to the right. Good catch!
