Redrockjk
Thanks for this information!
So there is an updated steering stabilizer with AC part # from FCA?
I found the AB Steering damper on mopar website.
68251580AB
You also stated updated track bar in your post. Is there also an updated track bar from FCA or were you referring to an aftermarket track bar?
Also, is it not necessary to install a longer track bar when installing a 2” lift? I would think the stock track bar length would cause the axles to be offset after installing the lift.
Trac bar is a AC from an AB and something changing with the stiffness of the bushing rubber....Actually I think the damper is an AD now and no it’s not absolutely necessary to install a track bar as it’s 1/2-5/8s off center
