Perfect steering, now death wobble
PAULY151
Paul
Myrtle beach
2019 jeep wrangler unlimited jl
Steering was perfect. Just installed a 2.5 lift, now I get the death wobble only around 45 to 60 mph. Thoughts? Fix?
Tumbleweed
Anthem AZ
18' JLU Auto 3.6L
Make sure the vehicles on the ground. Loosen and retorque the trackbar, upper and lower control arms, and sway bar links
Edit. Also check the torque of the trackbar bracket if applicable. Verify the axle is centered if it’s an adjustable trackbar
tatarin
Russ
Bloomingdale, IL
2019 MOAB Mojito Sky One-Touch, 2015 Lexus RX350F-sport, 2005 Camry SE
Axles could be off center, did install adjustable track bars?
JimLee
Jim
Too damn close to Death Valley
'19 JLU
Alignment? Increased caster (around 6)? Toe in set toward the high side? Tires balanced and inflated properly? Mine was perfect prior to lifting and then all over the place after, correcting these issues has my steering better than factory.
Icon Vehicle Dynamics
