Steering wheel heat not working
Anand saroop singh
Anand
Winnipeg
Wrangler
I have wrangler 2021 and last day I noticed my steering heat is not staying on , it shuts off after 2 3 seconds if anyone know about this let me know
aldo98229
Aldo
Bellingham, WA
Market Research
That doesn’t sound right.
Are you getting any other messages that might suggest that one of your batteries is not holding charge?
If not, sounds like a dealer visit is in order.
Good luck.
Anand saroop singh
Anand
Winnipeg
Wrangler
Good luck.
No there’s no other messages or sign indicating, all the rest of switches work great but not the steering heat on/off switch
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Several potential failure points. Do the heated seats work okay?
areuriding
Ken
Manassas Park Va.
2021 Wrangler Rubicon XR/2026 Rubicon X on order
Semi Retired
Trip to the dealer as much as you may hate that.
cheekibreeki
Virginia
19 Sahara JL
It won't give you a message, it's tripping itself and shutting off. They have a safety mechanism built in where it will turn off after a certain temp. it's typically the module part#68438109AC, pretty cheap if out of warranty. But other than that it would either be the wiring or the steering wheel itself.
mwilk012
Oklahoma
Service
How competent are you with a voltmeter?
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
2 points from your owner's manual:
The heated steering wheel may not turn on when it is already warm.
The engine must be running for the heated steering wheel to operate.
