Steering Wheel Buttons Not Working
Nelson's Willys
Travis
South Carolina
2024 Willys
2024 JLU with 4,000 miles. All buttons on front and back of steering wheel are not working, except for the cruise buttons. Thinking maybe a fuse? Any ideas and what possible fuse. Thanks!
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
First of all, if you haven't done so already, open your fuse box and make sure every fuse is fully inserted. The factory is notorious for not inserting fuses all the way. This might resolve your problem.
I'm not sure what fuse it is but even if it's just a blown fuse I'd take to the dealer. You're well within warrantee and fuses should not blow. Get this issue documented because replacing a fuse is not going to resolve what blew the fuse in the first place.
They'll probably just replace the fuse and send you on your way. But it will give you much better legs to stand on if the fuse blows again.
jludave
The Isle of Long
IT Manager
Might not be a fuse. You might have a bad clock spring. Either way, you are under warranty. Take it back to your dealer and have them fix it.
Spunky
Keith
North Chesterfield, VA
1992 Cherokee XJ, 2024 Wrangler JLURX
PetroChemicals R&D
I have a ‘24 JLURX and the cruise control stopped working at 700 miles. There is an error light on for the adaptive cruise. I pulled a P0585 code…speed control switch correlation. The dealer is going to start with replacing the cruise control switches.
Some Wranglers have had problems with the clock spring. Does your horn work? It is sad to be having these problems with such low mileage.
Hd088
Hassan
Brooklyn ny
Jeep wrangler JLU 2021
Hi did u find out the problem im having same exact issue with my 2024 JL with 2500 miles on help please I checked my fuse box all looking good
jludave
The Isle of Long
IT Manager
You’re under warranty. Take it to the dealer. Not worth trying to mess with/fix it yourself.
Hd088
Hassan
Brooklyn ny
what was the issue?
I made a appointment with dealer ship next week so I will let u know soon im still under warranty im sure Will cover its steeering heating and button and streering dashboard freeze
Hd088
Hassan
Brooklyn ny
what was the issue?
Okay so I went to dealer today they checked said I got my jeep lifted and wheel alignment was done not right** so dealer told me its something called clutch spring pins which is idk but he said will cover warranty!!! right now backed up on order gone go back when ever part arrive which could take about an month or weeks
