Steering Wheel Audio Control
dcarey13
New York
Wrangler JL
Just brought home a new 2-door JL - so very cool!! - and have a question about the audio controls on the steering wheel. When uConnect is in SAT mode, the buttons on the back left hand side of the steering wheel work as follows:
* Up/Down buttons switch the SAT channel up/down one station.
* The center button cycles up (not down) through FAV settings.
Is there any way to alter this? I would prefer that the up/down buttons cycle through the favorite settings rather than individual channels.
Thanks
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
As stated ..... NOPE
LincolnSixAlpha
Arizona
Well, this is just sad, my 2015 Silverado would only flip through my "saved" favorites stations. I'm sure this could easily be remedied with a firmware update, and I hope that it is. I love the radio, and the Uconnect system, but I do find it to be an inconvenience to change channels (my saved) via the display when I'm driving on the highway with high winds, and maniacs.
Jeepsterfreak
Honda, Future JLU
Have you tried pressing and holding the up/down buttons to see if takes you to your next saved channel? My Honda will switch to next saved station with one press or you can press and hold to scan to next available station.
At minimum, you can press the center button on the back of the steering wheel to select the next higher saved station so you don’t have to switch via the display.
You can also use voice commands to change the station (according to owner’s manual).
LincolnSixAlpha
Arizona
No, I have not, but thank you for the suggestion. I will try what you suggested. Worst case, to your point, is to just get used to the voice commands perhaps.
caged
Rodger
Elliot Lake, Ontario
1949 CJ3a 90XJ 00XJ 97TJ 18JLR
i don't mind it this way, but i wish it was volume on that side, and channel surf on the right. because, if my hand is on the shifter, and i want to turn up the volume, i will just reach for the big rubber knob, rather than put that hand on the steering wheel to turn up the radio. my left hand is always on the wheel, so volume at that hand would make more sense. my VW was that way.
LincolnSixAlpha
Arizona
I thought I'd post a follow up to this. From JeepstersFreak suggestion, I depressed both the "up, and down" buttons on the left side for changing the channel, and ultimately discovered that the there's also a small button you can press on top of the up/down buttons. Using this button will cycle upwards through your saved stations, as I want. It's only upwards, but I only have about 7 channels I listen to anyhow, so this works great for me.
Conversely, on the opposite side where you control the sound volume, the button that exists on that side will control your input, cycling through SiriusXM, FM, AM, and any of your Bluetooth/USB devices.
Jeep Wrangler JL Steering Wheel Audio Control 2018-10-28_13-11-38
se7en
Knoxville, TN
2024 Rubicon X / Zynith / 3.6 Auto / SOT / XR
...and ultimately discovered that the there's also a small button you can press on top of the up/down buttons. Using this button will cycle upwards through your saved stations, as I want. It's only upwards, but I only have about 7 channels I listen to anyhow, so this works great for me.
Thanks for your post and picture, but the OP already said that in his second bullet.
gofastguy
Ohio
2018 JL Rubi 2019 WK Trailhawk 2015 Mustang GT
Thanks for the close up pics. I've been wondering what was up with these buttons and hadn't gotten around to figuring out the deal with these yet!
LincolnSixAlpha
Arizona
Sure thing. I understand how you feel, I've been feeling a tiny bit overwhelmed with some of the settings, etc, and have not made the time to read up.
