ThirtyOne
- Apr 18, 2017
- Chapel Hill, NC
- Website
- www.jeepdoodles.com
- 2021 JLU Rubicon, 2017 Chevy Tahoe
- Build Thread
- Link
Y’all crack me up.
No. If you change any preset up or down 1 the center will take you to Preset 1.Yes up only. So if you are on preset 2 and need to get to 1 just hit it 11 times.
You can start back at the 1st preset if you click the top or bottom buttons once, which put you at the next channel up/down from a preset. Then hit the center preset button and it will start you back at the 1st preset. Not elegant but it shortens getting to presets. If you find that you are using presets 6+ more than the 1st 5 presets it might help to reorder the presets.Yes up only. So if you are on preset 2 and need to get to 1 just hit it 11 times.
I have wished for this since I first drove my JK before this JL. It makes no sense to have the volume on the right behind the wheel, when it is just a few inches from the actual radio knob. And as you pointed out, it is unusable when shifting gears. These have been many times when downshifting because I am slowing down, that I also need to reduce the volume.It would have been nice if Jeep allowed us to swap the left and right hand controls. Mine has a manual transmission and there have been times where I was busy shifting and would like to have reduced the audio volume but both required my right hand.
You guys are using them all wrong. I get so many more presets by using them to go to ranges. And yes, if you are not on a preset, hitting the center button takes you back to your first preset. So for me, that is Ch 2. Then the next button programmed is 7, then 10. I like all the decade stations, so for me, I will press center button to go from 2 to 7, then use the up button to go 8, 9, 10, then on 10, hitting the center button then jumps to 15, then I use the up arrow to do 16, 17, then center button to jump to 25.You can start back at the 1st preset if you click the top or bottom buttons once, which put you at the next channel up/down from a preset. Then hit the center preset button and it will start you back at the 1st preset. Not elegant but it shortens getting to presets. If you find that you are using presets 6+ more than the 1st 5 presets it might help to reorder the presets.
YesSo the bump in the center goes through the presets?
@joe@zautoMaybe switching the left and right fingertip functions can be the next addition to the Tazer?
Yeah, I used this workaround when I had SXM in my truck. I have the free trial in the Jeep right now and don't even listen to that.You guys are using them all wrong. I get so many more presets by using them to go to ranges. And yes, if you are not on a preset, hitting the center button takes you back to your first preset. So for me, that is Ch 2. Then the next button programmed is 7, then 10. I like all the decade stations, so for me, I will press center button to go from 2 to 7, then use the up button to go 8, 9, 10, then on 10, hitting the center button then jumps to 15, then I use the up arrow to do 16, 17, then center button to jump to 25.
My only issue is that the radio records all you presets from the time your radio is turned on (on the 8.4), and using my method above records a couple stations I might not rewind as much. But that is a real 1st world problem, and having that feature far out weighs any cons. Oh and on replay, the up down buttons should change to "jump forward/back".
