Steering upgrade needs
ducatijosh
Josh
DFW
2022 Jeep Wrangler High Tide
Hey guys
I have a buddy that needs new steering for his Gladiator Mojave
Looking at the steer smarts bottom mount drag link and tie rod
https://www.morris4x4center.com/steer-smarts-yeti-xd-jl-bottom-mount-draglink.html
https://www.morris4x4center.com/steer-smarts-yeti-xd-jl-rubicon-tie-rod-assembly-long-length.html
With this we're looking to add the Fox 2.0 TS steering stabilizer
https://www.morris4x4center.com/fox-performance-series-2-0-ts-stabilizer.html
For some reason everyone mounts these to the tie rod instead of the axle so I guess we'll need the stabilizer bracket
https://www.morris4x4center.com/special-order-parts-4.html
And possibly a bolt to mount the stabilizer to it though this says ats?
https://www.morris4x4center.com/ste...er-bracket-bolt-for-fox-ats-stabilizer-1.html
Do we have everything right so far? The only thing I dont understand is the passenger side mounting point, usually there's a bolt hole off of the tie rod but I do not see that in the part pictures nor do I see it mentioned anywhere.
I know this relocation bracket is an option but it's it a requirement?
https://www.morris4x4center.com/yeti-xd-steering-stabilizer-relocation-bracket-axle-side.html
Thanks!!
Apples491
Nick
Denver, CO
2022 JLUR in Hydro Blue, 2024 Nissan Ariya
Apples491
Nick
Denver, CO
ducatijosh
Josh
DFW
Sweet thanks, we'll pick up the JK version, that helps a lot. What about the eyelet attachment point? Where does that go?
ducatijosh
Josh
DFW
Ah okay, I see the longer bolt on the JK steering stabilizer, we'd just use that on the JT?
rickinAZ
Phoenix
2026 MOAB 392
Hey guys
Thanks!!
You jumped right to the conclusion without telling us about the problem. Has he measured his castor? That might be the issue right there with throwing parts at it.
Apples491
Nick
Denver, CO
I believe so. I used the bracket with my falcon stabilizer so I never had to deal with that specifically.
Edit. Yes. If you look at the install instructions, they show you using the longer bolt through the draglink lower mount
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Hey guys
Thanks!!
I used to have that exact combination of parts on my JLUR. Others have already showed you the JK stabilizer, which is a great shortcut vs swapping the JL bracket for a tie rod clamp.
Jeep Wrangler JL Steering upgrade needs 20200613_202559
Apples491
Nick
Denver, CO
It looks like you've got the relocation bracket too. Interesting that people were reporting that it won't work with Fox stabilizers.
Headbarcode
LI, New York
Any stabilizer shock for a JL will have the same bushing width and through bolt size on the rod end, and will work with the SteerSmarts axle side relocation bracket.
The possible issue would be if someone was trying to install the stabilizer backwards, with the shock body bushing on the axle side. The through shaft would hit the ear of the relocation bracket. The only other possible issue, is if the stabilizer was oriented correctly, but a regular hex head bolt was used to attach the tie rod clamp. It would have too high of a profile and interfere with the through shaft, which is why the lower profile countersunk bolt is needed.
hoag4147
Colleyville, TX
2022 JLUR XR
Oh how things have changed under there ?
ducatijosh
Josh
DFW
Problem is his drag link went bad and the dealership says it has to sit on the lot for 6 months waiting for backordered oem parts.
what does caster have to do with a bad drag link ?
JLanesey
Joseph
Connecticut
2018 JL sport, 1954 CJ3B
HVAC
I’m awaiting delivery of crate d44s. Any input on best solution so far? Is the yeti stuff working out good?
ducatijosh
Josh
DFW
Yeah it’s all working great. Got it all installed
