Steering Stabilizers
bodam
Bob
Cypress, TX
2018 Jeep Wrangler
I would say it's well worth the $54
kkuntz01
Kevin
Mount Juliet, TN
2018 JLU Rubicon, 2014 Ram 2500 Crew Cab
Besides the price and part count, what’s the difference between the single stabilizer and dual stabilizer?
Unless you are running a ridiculously heavy E range tire there should be no reason any nominally built should ever need dual stabilizers. I’m on 37’s on my JL using the stock stabilizer and only plan to change when I put a real lift on it.
Besides, when you think about it, all a stabilizer does is mask a steering problem.
PaPasJP
Gainesville, FL
I want to get the stabilizer out of the way.
What is the best relocation you recommend?
Roky
Roky
Mask, bandaid, whatever you want to call it, and I agree not to get one to fix steering problems, but if you’re on 35s or larger tires, a good aftermarket ss will make steering feel better on these new jls for sure. Just my .02....:)
Bearman95
Chuck
Ft. Worth
2018 JL Rubicon
Mask, bandaid, whatever you want to call it, and I agree not to get one to fix steering problems, but if you’re on 35s or larger tires, a good aftermarket ss will make steering feel better on these new jls for sure. Just my .02....:)[/QUOTE The Falcon 2.2 stabilizer made my Rubicon drive better with a 33’s on it. I did not have any steering problems. But I put the falcon 2.2 on my Rubicon prior to the 315 70 17 tires and Mopar 2 inch lift. I wanted the ability to adjust the steering as I had on my grand Cherokee Overland. It was a big improvement over stock steering!
Visible15
Massachusetts
2018 Wrangler JL Sahara
Appreciate the feedback! Don’t know if I’ll put a lift on, and thus probably no stabilizer at all
jruss
Josh
Greater Baton Rouge Area
2018 Jl Sport Unlimited
So is the Rough Country better than the stock stabilizer? I will gladly spend the money if it handles better at highway speeds.
Rough country markets to lack of experience. They are trash, almost everything they make is trash. I have seen rough country suspension and steering components fail at a faster rate than any other manufacturer. Dv8 rebrands rough country and e auto grills. Same boat.
