Steering stabilizer removal on Rubicon
Mmorreale
Houston, Texas
2024 JL Willys 2 door
Retired (disabled) Firefighter
I am looking at purchasing a Rubicon 4XE. I am disabled so I have issues with turning the steering wheel with the steering stabilizer. I was curious if anyone knew if it could be removed without problems. Id hate to remove it and have steering issues so I’d like to know before ordering. Thanks in advance.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Not a great idea, but there are hydraulic power steering mods available. Have you test driven one?
DuRsT
US
2021 Unlimited Rubicon
I’m a bit confused. The new Rubicon’s can be driven with two fingers, very little steering effort required.
I don’t think removing the steering stabilizer would change steering effort, it would only transmit more of the rattles and bumps from the road to the steering wheel itself.
Mmorreale
Mmorreale
Houston, Texas
Yes I test drove a Sahara and a Rubicon back to back last year and the Rubicon steering was pretty tough because of the stabilizer. I have a spinal cord injury so upper upper body strength is lower.
I purchased a Sahara but now I have to sell it because I’m having trouble at the diesel pump. So I want a hybrid and the only way to get that is either Sahara Rubicon and I would rather the Rubicon.
mwilk012
Service
The steering stabilizer is exactly the same on the Rubicon and the Sahara.
MARSHMELLA
Kirt
FL
2021 JLUR
Military
My guess is that the steering wheel was harder to turn on the Rubicon due to the tires being taller, wider, and a more aggressive tread design.
Another option would be to add a hydronic steering assist kit. You could turn the wheel with just your pinky after that.
I hope you find what you want.
Mmorreale
Mmorreale
Houston, Texas
Is that a disability thing or is that an aftermarket steering option? I know that my local disability vehicle dealer can get me a prescription to modify my steering but it’s really really expensive like $4000
Mmorreale
Mmorreale
Houston, Texas
Really, that’s good information to know. I have 35s on my Sahara and I have no trouble. I think I should go test drive again. Thanks for the information.
MARSHMELLA
Kirt
FL
2021 JLUR
Military
limeade
Guy
Reno, NV
If the steering and suspension is working correctly (judging by the number of threads and posts, that isn't always the case), you can remove the steering stabilizer without any ill effects. The steering stabilizer does help remove/dampen some of the felt forces from the road, such as pot holes, bumps, cracks, etc. With the stabilizer removed, these forces will cause the steering wheel to rock side to side a little more.
I had mine removed for a week after I installed my first lift and had no issues. If you can find someone willing to remove it for you, give it a test drive and see if you're ok with how the steering feels.
JPAloha
Saskatoon
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE, 2018 JL Rubicon 2 door
Accredited Financial Planner
Get the Falcon adjustable steering stabilizer, it has a soft setting which feels much lighter than the stock stabilizer (I use the medium setting on mine which replicates stock feel).
Mmorreale
Mmorreale
Houston, Texas
That’s a great idea thank you for that information.
word302
Oregon
JLU
MARSHMELLA
Kirt
FL
2021 JLUR
Military
