Durango_Bill
Our JLUD had issues in Moab on steep obstacles- transmission would jump out of gear, into neutral, show a transmission problem light on the dash and not function until the jeep was turned off and restarted.
if I took a slightly less steep line, everything worked perfectly fine and zero issues anywhere but really steep sections of rocks/trails…
anyone ran across this issue and what was the root cause?
note: transmission is properly filled and serviced, double checked after the first climb failure
